Fingerprint sensor as a momentary switch
Is it possible to use the r503 fingerprint sensor like a momentary pushbutton that is only on while the pad is touched and goes off when the finger is lifted?
This works, to open a lock using delay, but I would rather it simply stayed on while being touched.
This is just the library example with the addition of making pin 12 output.
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit finger detect test");
 //pin for relay
  pinMode(12, OUTPUT);
  digitalWrite(12, HIGH);
  // set the data rate for the sensor serial port
  finger.begin(57600);
  delay(5);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) {
      delay(1);
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
  finger.getTemplateCount();
  if (finger.templateCount == 0) {
    Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
  else {
    Serial.println("Waiting for valid finger...");
    Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
void loop()                     // run over and over again
  getFingerprintID();
  delay(50);            //don't ned to run this at full speed.
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      //Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  digitalWrite(12, LOW);
  delay(2000);
  return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  p = finger.fingerFastSearch();
  // found a match!
I’m surprised that SoftwareSerial works reliably at 57600 bps !
Wasting cpu cycles !
Where is the relay actioned… I’m guessing it’s on pin 12, but why use magic numbers instead of named variables ?
To solve your problem, you need to determine when a valid finger is present, then keep testing until it’s lifted off.
Thank you for your reply.
This is straight from the example, whoever wrote it knows much more than I do. It does seem to be pretty reliable in the last few days.
I have changed this, didn't know any better.
I spent some time trying to figure this out. Any examples I found used an input pin to test for activation and the fingerprint sensor doesn't actually use an input pin. It uses RX an TX.
I know I'm probably going about it all wrong I have gotten it to work, kind of using this
  interface
//sets pin 12 to open lock
const int lockPin = 12;
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
#else
#endif
  delay(100);
  //Serial.println("\n\nAdafruit finger detect test");
  //pin for relay
  pinMode(lockPin, OUTPUT);
  digitalWrite(lockPin, HIGH);
  delay(5);
    while (1) {
      delay(1);
  else {
  getFingerprintID();
  switch (p) {
      //Serial.println("Image taken");
     digitalWrite(lockPin, LOW);
    Serial.println ("unlock");
    Serial.println ("lock");
      return p;
      return p;
      return p;
    default:
      return p;
  // OK success!
  switch (p) {
      // Serial.println("Image converted");
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
    return p;
    Serial.println ("lock2");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.println(finger.fingerID);
  //Serial.print(" with confidence of "); Serial.println(finger.confidence);
    // read the fingerprint:
    buttonState = digitalRead(p == FINGERPRINT_OK);
    if (buttonState == p == FINGERPRINT_OK){
    Serial.println ("on");
    // compare the buttonState to its previous state
    //else{ (buttonState == p == FINGERPRINT_NOTFOUND);
    else{ (buttonState != p == FINGERPRINT_OK);
    Serial.println ("off");
    //delay(50);
  // found a match!
This works, on and stays on as long as finger is on the pad and goes off when finger lifted. The problem is that if you use a finger that isn't registered it cycles on and off as long as the wrong finger is used.
Most of my changes start at line 100 with some things I tried and didn't seem to work around line 170.
This is for the lock on a cabinet and is the ONLY thing this arduino is going to do so I could simply unlock it and use delay to simply reset the lock. Just wanted to get it going this way if I can.
I made this up entirely by inference, not because i know anything at all about finger print sensors.
Insert this instead of your digital writings and delays.
  // found a match!
  while (finger.getImage() == FINGERPRINT_OK) { }    // hang here looking as long as we see the finger
//Serial.println("finger no longer detected");
Maybe it works. It is rude because it hangs. The same call to the getImge() method cou,d be used in better code that is just checking once per loop or something like that.
But if you've nothing better to compute whilst the finger is on the sensor, this might be OK.
a7
Sorry, I did not read carefully at all your description of the real problem.
Neither do I understand it, and I think whatever I did would not have the same problem. I would not be hanging it up waiting for a finger to go away if a finger successfully open the lock and got as far as where my snippet should be placed.
a7
