hi friends,
we are doing a project to lock/unlock door using fingerprint sensor mentioned in title.Everything is fine as i got main code and slightly modified and its working pretty well. The sensor which i mentioned has a feature called power saving mode that when i touched its frame the led inside will on otherwise it will go to off mode.So i made a simple code by myself to switch on led and off and its also went well. But when i combined main code and led code none of them are working, i am attaching both code here, can anyone able to help by combining both .Any doubt on my quest please ask
Main code follows,
FPS_IDFinger.ino - Library example for controlling the GT-511C3 Finger Print Scanner (FPS)
Created by Josh Hawley, July 23rd 2013
Licensed for non-commercial use, must include this license message
basically, Feel free to hack away at it, but just give me credit for my work =)
TLDR; Wil Wheaton's Law
Description: This sketch will attempt to identify a previously enrolled fingerprint
saved in its database.
This code should work with the any model of ADH-Tech's FPS as long as
you are within the minimum logic level threshold for the FPS serial UART.
This code has been tested with these models:
GT-521F52 [ https://www.sparkfun.com/products/14585 ]
GT-521F32 [ https://www.sparkfun.com/products/14518 ]
GT-511C3 [ https://www.sparkfun.com/products/11792 ]
GT-511C1R [ https://www.sparkfun.com/products/13007 ]
-------------------- HARDWARE HOOKUP with 5V Arduino --------------------
1.) Dedicated Bi-Directional Logic Level Converter (LLC)
It is recommended to use a dedicated bi-direcitonal LLC
[ https://www.sparkfun.com/products/12009 ] for a reliable connection if you
are using a 5V Arduino microcontroller:
Fingerprint Scanner (Pin #) <-> Logic Level Converter <-> 5V Arduino w/ Atmega328P
UART_TX (3.3V TTL)(Pin 1) <-> LV1 <-> HV1 <-> RX (pin 4)
UART_RX (3.3V TTL)(Pin 2) <-> LV4 <-> HV4 <-> TX (pin 5)
GND (Pin 3) <-> GND <-> GND <-> GND
Vin (3.3V~6V) (Pin 4) <-> HV <-> 5V
LV <-> 3.3V
2.) Voltage Division w/ 3x 10kOhm Resistors
Otherwise, you could use 3x 10kOhm resistors [ https://www.sparkfun.com/products/11508 ]
to divide the voltage from a 5V Arduino down to 3.3V FPS similar to the
"Uni-Directional" application circuit on our old logic level converter
[ https://cdn.sparkfun.com/assets/b/0/e/1/0/522637c6757b7f2b228b4568.png ]:
Voltage Divider <-> Fingerprint Scanner(Pin #) <-> Voltage Divider <-> 5V Arduino w/ Atmega328P
<-> UART_TX (3.3V TTL) (Pin 1) <-> <-> RX (pin 4)
GND <-> 10kOhm <-> 10kOhm <-> UART_RX (3.3V TTL) (Pin 2) <-> 10kOhm <-> TX (pin 5)
GND <-> GND (Pin 3) <-> GND <-> GND
<-> Vin (3.3V~6V) (Pin 4) <-> <-> 5V
Note: You can add the two 10kOhm resistors in series for 20kOhms. =)
#include "FPS_GT511C3.h"
#include "SoftwareSerial.h"
// set up software serial pins for Arduino's w/ Atmega328P's
// FPS (TX) is connected to pin 4 (Arduino's Software RX)
// FPS (RX) is connected through a converter to pin 5 (Arduino's Software TX)
FPS_GT511C3 fps(4, 5);
const int buttonPin = A1;
int buttonState = 0;// (Arduino SS_RX = pin 4, Arduino SS_TX = pin 5)
/*If using another Arduino microcontroller, try commenting out line 53 and
uncommenting line 62 due to the limitations listed in the
library's note => https://www.arduino.cc/en/Reference/softwareSerial . Do
not forget to rewire the connection to the Arduino*/
// FPS (TX) is connected to pin 10 (Arduino's Software RX)
// FPS (RX) is connected through a converter to pin 11 (Arduino's Software TX)
//FPS_GT511C3 fps(10, 11); // (Arduino SS_RX = pin 10, Arduino SS_TX = pin 11)
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
fps.UseSerialDebug = true;//set up Arduino's hardware serial UART
fps.Open(); //send serial command to initialize fps //turn on LED so fps can see fingerprint
// Identify fingerprint test
if (fps.IsPressFinger())
fps.CaptureFinger(false);
int id = fps.Identify1_N();
/*Note: GT-521F52 can hold 3000 fingerprint templates
GT-521F32 can hold 200 fingerprint templates
GT-511C3 can hold 200 fingerprint templates.
GT-511C1R can hold 20 fingerprint templates.
Make sure to change the id depending on what
model you are using */
if (id == 0) //<- change id value depending model you are using
{//if the fingerprint matches, provide the matching template ID
Serial.print("Verified ID:");
Serial.println("lock");
digitalWrite(8, HIGH);
else if (id == 1) {
Serial.println("unlock");
digitalWrite(8,HIGH);
digitalWrite(9,HIGH);
delay(600);
digitalWrite(9,LOW);
else if (id == 2) {
Serial.println("off");
digitalWrite(8, LOW);
else if (id == 3) {
Serial.println("up");
digitalWrite(10, HIGH);
delay(5000);
digitalWrite(10, LOW);
{//if unable to recognize
Serial.println("Finger not found");
Serial.println("Please press finger");
delay(100);
Led on /off code follows,
const int ledPin = 9;
Serial.begin(9600); //set up Arduino's hardware serial UART
fps.UseSerialDebug = true; // so you can see the messages in the serial debug screen
fps.Open(); //send serial command to initialize fpspinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
if (buttonState == 1) {
fps.SetLED(true); // turn on the LED inside the fps
delay(8000);}
else {
fps.SetLED(false); // turn on the LED inside the fps
delay(1000);}
please help us guys,we are stuck now
