Hi!
I need some help to my project.
I have to connect Fingerprint sensor, I2C LCD and an SD Shield V1.0 with Arduino UNO. Fingerprint's code works well and the LCD code too but just separately. (the SD Shield is not connected yet) I found a code and it doesn't write error, but not works well..
I have attached a photo how it's looks like. The Fingerprint sensor is not works just the LEDs and LCD.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
#include <Adafruit_Fingerprint.h>
#if ARDUINO >= 100
#include <SoftwareSerial.h>
#else
#include <NewSoftSerial.h>
#endif
uint8_t getFingerprintEnroll(uint8_t id);
int k;
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(11, 12);
#else
NewSoftSerial mySerial(11`, 12);
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id = 0;
lcd.begin(16, 2);
lcd.print("FingerPrintSensor");
Serial.println("fingertest");
//mySerial.print("Detect");
// set the data rate for the sensor serial port
finger.begin(9600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
}lcd.clear();
void loop() // run over and over again
Serial.println("Type in the ID # you want to save this finger as...");
lcd.print(" ID=" );
//lcd.print(k);
// while (true) {
// while (! Serial.available());
// char c = Serial.read();
// if (! isdigit(c)) break;
// id *= 10;
// id += c - '0';
id++;
Serial.print("Enrolling ID #");
Serial.println(id);
lcd.print(id);
while (! getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(uint8_t id) {
uint8_t p = -1;
Serial.println("Waiting for valid finger to enroll");
lcd.print("Put the Finger");
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
default:
Serial.println("Unknown error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
