#include <WiFi.h>
#include <FirebaseArduino.h>
// Replace with your network credentials
const char* ssid = "Khusus_Atakamo_Bawah1";
const char* password = "BagiBagiPangkalRugi";
// Replace with your Firebase project information
const char* firebaseHost = "percobaan-c5f50-default-rtdb.asia-southeast1.firebasedatabase.app";
const char* firebaseAuth = "duj7fwoPf9govFtyF4kWw24IU9BROs667cqs6WSR";
// Pin definitions for the sensors
const int temperaturePin = A0;
const int humidityPin = D1;
const int lightPin = D2;
// Start the serial communication
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
// Connect to Firebase
Firebase.begin(firebaseHost, firebaseAuth);
// Read sensor data
int temperature = analogRead(temperaturePin);
int humidity = analogRead(humidityPin);
int light = analogRead(lightPin);
// Print the sensor data to the serial monitor
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.print(", Humidity: ");
Serial.print(humidity);
Serial.print(", Light: ");
Serial.println(light);
// Send the sensor data to Firebase
Firebase.setInt("temperature", temperature);
Firebase.setInt("humidity", humidity);
Firebase.setInt("light", light);
// check the status of the Firebase connection
if (Firebase.failed()) {
Serial.print("setting number failed:");
Serial.println(Firebase.error());
chronology: firebase cannot be connected to arduino because there is no library file, even though the library has been installed and put in the library folder, after compiling and uploading it looks like this:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Destry Lia\OneDrive\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\DESTRY~1\AppData\Local\Temp\arduino_build_21316 -warnings=none -build-cache C:\Users\DESTRY~1\AppData\Local\Temp\arduino_cache_471150 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -verbose C:\DHT-sensor-library-master\sprinkler_2\sprinkler_2.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Destry Lia\OneDrive\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\DESTRY~1\AppData\Local\Temp\arduino_build_21316 -warnings=none -build-cache C:\Users\DESTRY~1\AppData\Local\Temp\arduino_cache_471150 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -verbose C:\DHT-sensor-library-master\sprinkler_2\sprinkler_2.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\Destry Lia\OneDrive\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\DESTRY~1\\AppData\\Local\\Temp\\arduino_build_21316/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "C:\\Users\\DESTRY~1\\AppData\\Local\\Temp\\arduino_build_21316\\sketch\\sprinkler_2.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFi@1.2.7 WiFiNINA@1.8.13]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@1.2.7 WiFiNINA@1.8.13]
"C:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\DESTRY~1\\AppData\\Local\\Temp\\arduino_build_21316/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Destry Lia\\OneDrive\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\nodemcu" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\libraries\\WiFi\\src" "C:\\Users\\DESTRY~1\\AppData\\Local\\Temp\\arduino_build_21316\\sketch\\sprinkler_2.ino.cpp" -o nul
Alternatives for FirebaseArduino.h: []
ResolveLibrary(FirebaseArduino.h)
-> candidates: []
sprinkler_2:2:10: fatal error: FirebaseArduino.h: No such file or directory
Multiple libraries were found for "WiFi.h"
2 | #include <FirebaseArduino.h>
Used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\WiFi
Not used: C:\Users\Destry Lia\OneDrive\Documents\Arduino\libraries\WiFiNINA
compilation terminated.
Using library WiFi at version 1.2.7 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\WiFi
exit status 1
please give us solutions for this problem, thank you
