i'm trying to update the firmware from Nina Wifi W102 of my Arduino nano rp2040.
I tried the Arduino IDE 2.2.1, the IoT cloud and the command line tool arduino-fwuploader_2.4.1_macOS_ARM64.
Nothing gives me positive result.
Command line tool tells me, the firmware version is 99.99.99 ??
Here is the output of the command line tool:
drj@Air-von-drj arduino-fwuploader_2.4.1_macOS_ARM64 % ./arduino-fwuploader firmware get-version -b arduino:mbed_nano:nanorp2040connect -a /dev/cu.usbmodem101
rp2040load 1.0.6 - compiled with go1.16.2
Loading into Flash: [==============================] 100%
FIRMWARE-VERSION: 99.99.99
Firmware version installed: 99.99.99%
drj@Air-von-drj arduino-fwuploader_2.4.1_macOS_ARM64 % ./arduino-fwuploader firmware flash -b arduino:mbed_nano:nanorp2040connect -a /dev/tty.usbmodem101 -v -i NINA_W102-v1.5.0-Nano-RP2040-Connect.bin
INFO[0000] arduino-fwuploader Version: 2.4.1 Commit: d945078 Date: 2023-08-31T07:43:01Z
INFO[0000] Checking signature index=/private/var/folders/2m/1f834y_n2lj2jhsf573f0bt00000gn/T/55770067919477794101887039005/index.json signatureFile=/private/var/folders/2m/1f834y_n2lj2jhsf573f0bt00000gn/T/55770067919477794101887039005/index.json.sig trusted=true
INFO[0000] Checking signature index=/private/var/folders/2m/1f834y_n2lj2jhsf573f0bt00000gn/T/fwuploader/package_index.json signatureFile=/private/var/folders/2m/1f834y_n2lj2jhsf573f0bt00000gn/T/fwuploader/package_index.json.sig trusted=true
INFO[0000] Checking signature index=/private/var/folders/2m/1f834y_n2lj2jhsf573f0bt00000gn/T/fwuploader/plugin_firmware_index.json signatureFile=/private/var/folders/2m/1f834y_n2lj2jhsf573f0bt00000gn/T/fwuploader/plugin_firmware_index.json.sig trusted=true
INFO[0002] Uploading firmware (try 1 of 9)
time=2023-10-20T14:59:21.545+02:00 level=INFO msg="upload command sketch"
time=2023-10-20T14:59:21.549+02:00 level=INFO msg="sending serial reset"
time=2023-10-20T14:59:32.132+02:00 level=INFO msg="bootloader port" address=/dev/tty.usbmodem101
time=2023-10-20T14:59:32.141+02:00 level=INFO msg="uploading command sketch"
time=2023-10-20T14:59:37.066+02:00 level=INFO msg="new serial port" address=/dev/cu.usbmodem101
time=2023-10-20T14:59:37.066+02:00 level=INFO msg="upload command sketch completed"
Error: serial port closed unexpectedly
ERRO[0051] couldn't update firmware: exit status 3
INFO[0051] Waiting 1 second before retrying...
INFO[0052] Uploading firmware (try 2 of 9)
time=2023-10-20T15:00:12.144+02:00 level=INFO msg="upload command sketch"
time=2023-10-20T15:00:12.147+02:00 level=INFO msg="sending serial reset"
^C
Does anyone have an idea, what i can do to get wifi work again?
Thank you for your help
Regards,
Juergen
