First code for oscillating motor...Be gentle!
I am a complete noob to programming firstly.
I am using a Arduino Nano with a A4988 stepper driver connected to a Nema11 stepper motor.
I wish to spin the motor in one direction (I dont care which) at 60-75rpm for ~20 seconds, then stop, reverse direction and repeat until I power off the device.
I have written the following code using "AccelStepper" library as it would be nice to slowly accelerate and decelerate, but I am unsure as to whether I have written a good code, partially or complete gibberish.
Speeds are calculated thus...250 steps per second at 200 steps per revolution gives me 1.25 revs per second or 75rpm.
200 steps for 20 seconds is 5000 steps.
I also apologise profusely if this is not the correct way to post code...Its only short and didnt know a better way.
// Include AccelStepper Library
#include <AccelStepper.h>
//Define motor pin connections
const int dirPin = 2;
const int stepPin = 3;
// Define motor interface type
#define motorInterfaceType 1
// Creates an instance
AccelStepper myStepper(motorInterfaceType, stepPin, dirPin);
  // set the maximum speed, acceleration factor,
  // initial speed and the target position
  myStepper.setMaxSpeed(350);
  myStepper.setAcceleration(50);
  myStepper.setSpeed(250);
  myStepper.moveTo(5000);
  // Change direction once the motor reaches target position
  if (myStepper.distanceToGo() == 10)
    myStepper.moveTo(-myStepper.currentPosition());
  // Move the motor one step
  myStepper.run();
Welcome to the forum. No need to,apologize, we can save that for later.:wink:
The only thing missing is… whether the sketch you posted does what it looks like at a glance, that is to say does it work?
Five programmers would come up with five different sketches all the way to what library they use, or if they even do use a library.
One would probably look a lot like your sketch,
What do you plan to do with steppers in the future?
a7
Why changing direction before it reaches the target? And I think it will go a little bit less with every cycle. Is that what you want to do?
No!
target should be 5000 steps (roughly 20 seconds of spinning then 20 seconds in reverse...then back again etc. So should my 10 be 5000 again?
I am not sure if it works...I am currently at work and my breadboard set up at home. I will check on it over the weekend (amongst other chores...booo!).
I am not sure what i want to do with steppers next. I am a mechanical engineer/designer by trade and have designed a lot around steppers, but never got into the coding side.
This is one of my old printers from about 13 years ago
No, it should be zero. distanceToGo tells the remaining steps until it reaches the target. So if it is zero, the target ( 5000 in your case) is reached, and you can reverse.
Even worse: distance to go is a signed value. when turning backwards it returns a negative value and will never get 10. So after one cycle forward/backwards it will stop. Of course this doesn't matter if you check for 0.
An be aware, when you tell it to go to -myStepper.currentPosition() it will not go back to 0, but back to position -5000 (in your case). So it will step 10000 steps backwards. from position +5000 to position -5000.
OK. Thanks.
So its starting from 0....Moving 5000 steps then into reverse and to -5000?
Could i just lose the reverse step (after void loop) and tell it to go to 5000 and then go to 0?
  myStepper.moveTo(0)
Yes, that's how it is now ( if you change 10->0 )
But you must do that in loop():
const long targetPos = 5000;
 //  myStepper.setSpeed(250);   // This is useless, as .run() only follows maxSpeed!
  if (myStepper.distanceToGo() == 0) {
    if (myStepper.currentPosition() == 0) {
      myStepper.moveTo(targetPos);
      myStepper.moveTo(0);
  myStepper.run();
Thats great! Thank you so much.
I will try it over the weekend and let you know.
