// 18 Mar 2018 - simple program to verify connection between Arduino
// and nRF24L01+
// This program does NOT attempt any communication with another nRF24
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <printf.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN);
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
printf_begin();
Serial.println("CheckConnection Starting");
Serial.println("FIRST WITH THE DEFAULT ADDRESSES after power on");
Serial.println(" Note that RF24 does NOT reset when Arduino resets - only when power is removed");
Serial.println(" If the numbers are mostly 0x00 or 0xff it means that the Arduino is not");
Serial.println(" communicating with the nRF24");
radio.begin();
radio.printDetails();
Serial.println("AND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1");
Serial.println(" and 250KBPS data rate");
radio.openReadingPipe(1, thisSlaveAddress);
radio.setDataRate( RF24_250KBPS );
And you want a picture of the wiring? (followed the same as the wiring diagrams posted by Robin2.. and posted the pin to pin connections already as well.(
but if you think an image is going to somehow help.. I'll post that too
SPI Speedz = 10 Mhz
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0x4141417852 0x4141417852
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0x4141417852
RX_PW_P0-6 = 0x20 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x01
CONFIG = 0x0e
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_MIN
SPI Speedz = 10 Mhz
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x21
CONFIG = 0x0e
Data Rate = 250KBPS
Model = nRF24L01+
PA Power = PA_MIN
How would anybody know about code posted elseware?
The Shakespeare type of wiring has the weakness that they don't tell all the rest, missing connections, power supplies etc.
I don't spend time on detective work to collect information. That's Your job.
So do appreciate the problem your asking the forum to solve, is to work out what exactly you are doing that is different.
I agree its something I'm doing.. (hence the comment what am I missing here?)
I double check the wiring.. but maybe my eyes are just glazing over it again and again?
Here is the UNO wiring..
Railroader:
Did you bother to even click the link? It was a DIRECT link to the CODE used in the specific post. No guessing.. No detective work. Just click the link.. look at the code that was used *(verbatim, no changes)
How would you know? (because I provided a LINK to the code for you????)
A lot of problems with those radios is that they can need more current than the Uno 3.3V regulator can provide.
From the tutorial:
Powering the nRF24L01+ module
The nRF24 modules require a 3.3v power supply. Be careful NOT to connect the VCC pin to a 5v power supply. I have found that they work satisfactorily when connected to the 3.3v pin on my Unos.
It is recommended to plce a 10µF capacitor across VCC and GND as near to the module as possible and I have found this essential when I made some units with an Atmega328 chip on a breadboard. The capacitor stabilizes the power supply for the module. However I have not found it necessary to use a capacitor with my Uno (or Mega). But if you believe you have followed all the other instructions correctly and are having problems it would certainly be a good idea to install a capacitor.
Why click on links when Forum has a function showing the code directly?
Convienient for You, inconvienent for me and no helping replies from me....
Your choice.
Railroader:
Your choice.
It was done on purpose to leave all the rest of the info in the tutorial as context. (thats alot to copy over when it already exists)..
If clicking a link is too much effort.. so be it. Appreciate your.....comments?
Either way its all appreciated. Guess I'll gave to do better next time and post everything here.
*to be clear.. BOTH Arduinos are working (Nano and Uno), using your 2-way comm example(s).. (thanks for those)
1.) Uno and Nano (clone)
2.) Low powered (PCB antenna)
3.) Here are the results from both boards:
UNO results:
