Hey there
I built a puzzlebox. To measure Time i added a 7-segment display. Also, i added a Neopixel-Ring that shows visualy how much time is left. The goal of the puzzle-box is to find 3 keys to the corresponding key-switches. Each key-switch has its own LED (10 mm LED) which turns on, when the key-switch is turned. To start the Game I added another push button with an LED inside. Also i added a DF-Player to play sound as soon as the game starts.
When i turn on the Arduino (Nano-Clone) everything looks fine and as intended. The "Start-button" is blinking an the 7-Segment-Display shows "Play".
The problem i'm facing is the following:
As soon as I push the "Start-button" one LED (or sometimes multiple) of the "Key-switch"-LED start flickering. Sometimes the 7-Segment display does not work properly (also flickering and not showing the remaining Time correctly).
Could it be, that I did something wrong in my Coding?
This is the code i'm using:
// Module connection pins (Digital Pins)
#define CLK 8
#define DIO 7
#include <FastLED.h>
#define numberOfSeconds(_time_) ((_time_ / 1000)% 60)
#define numberOfMinutes(_time_) (((_time_ / 1000)/ 60) % 60)
#include <TM1637Display.h>
#define NUM_LEDS 12 //Anzahl LEDs
#define DATA_PIN 4
CRGB leds[NUM_LEDS];
int seconds;
int minutes;
const byte startLED = 5;
const byte startButton = 6;
unsigned long startTime;
int startLEDBlink = 500;
const uint8_t OFF[] = {0, 0, 0, 0};
// .GFEDCBA
const uint8_t PLAY[] = {B01110011, B00111000, B01011111, B01101110};
const uint8_t LOST[] = {B00111000, B00111111, B01101101, B01111001};
TM1637Display display(CLK, DIO);
unsigned long timeLimit = 3606000;
unsigned long timeLimitLEDRing = timeLimit;
int Counter = 1;
const byte anzahlSchluessel = 3;
byte schluessel[anzahlSchluessel] = {3, 10, 12};
byte schluesselLED[anzahlSchluessel] = {2, 9, 11};
bool schluesselLastState[anzahlSchluessel] = {1, 1, 1};
bool schluesselCurrentState[anzahlSchluessel] = {1, 1, 1};
byte schluesselAlleSchluessel[anzahlSchluessel] = {0, 0, 0};
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
SoftwareSerial mySoftwareSerial(A0, A1); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
mySoftwareSerial.begin(9600);
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while (true) {
delay(0); // Code to compatible with ESP8266 watch dog.
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.volume(24); //Set volume value. From 0 to 30
pinMode(5, OUTPUT);
pinMode(6, INPUT_PULLUP);
display.setBrightness(0x0c);
display.setSegments(OFF);
FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS); // GRB ordering is typical
FastLED.setBrightness(100);
for (int i = 0; i < NUM_LEDS; i++) {
if (i < 7) {
leds[i] = CRGB::Green;
} else if (i < 10) {
leds[i] = CRGB::Yellow;
else {
leds[i] = CRGB::Red;
FastLED.show();
startTime = millis();
displayText();
for (int i = 0; i < anzahlSchluessel; i++) {
pinMode(schluessel[i], INPUT_PULLUP);
pinMode(schluesselLED[i], OUTPUT);
void countdown() {
long timeRemaining = timeLimit - millis();
while (timeRemaining > 0) {
if (timeRemaining <= ((timeLimitLEDRing - 2000) - (Counter * ((timeLimitLEDRing - 3000) / 12))) && Counter <= 12) {
leds[Counter - 1] = CRGB::Black;
Counter++;
FastLED.show();
seconds = numberOfSeconds(timeRemaining);
minutes = numberOfMinutes(timeRemaining);
display.showNumberDecEx(seconds, 0, true, 2, 2);
display.showNumberDecEx(minutes, 0x40, true, 2, 0);
schluesselCurrentState[i] = digitalRead(schluessel[i]);
if (schluesselCurrentState[i] != schluesselLastState[i]) {
if (schluesselCurrentState[i] == 0) {
digitalWrite(schluesselLED[i], HIGH);
else if (schluesselCurrentState[i] == 1) {
digitalWrite(schluesselLED[i], LOW);
schluesselLastState[i] = schluesselCurrentState[i];
if (memcmp(schluesselCurrentState, schluesselAlleSchluessel, 3) == 0) {
onSolve();
void displayText() {
display.setSegments(PLAY);
delay(2000);
void lost() {
myDFPlayer.play(3);
while (1) {
fill_solid( leds, NUM_LEDS, CRGB::Red);
FastLED.show();
fill_solid( leds, NUM_LEDS, CRGB::Black);
display.setSegments(LOST);
FastLED.show();
void onSolve() {
myDFPlayer.play(2);
delay(50);
myDFPlayer.volume(30);
while (1) {
digitalWrite(startLED, LOW);
leds[i] = CRGB::Black;
FastLED.show();
delay(50);
digitalWrite(startLED, HIGH);
FastLED.show();
delay(50);
if (digitalRead(startButton) == 1) {
if (millis() > startTime + startLEDBlink) {
if (digitalRead(startLED) == HIGH) {
else {
else if (digitalRead(startButton) == 0) {
timeLimit = timeLimit + millis();
myDFPlayer.play(1); //Play the first mp3
displayText();
countdown();
lost();
I tried to draw the circuit (DF-Player is connected to A0 and A1):
I tried changing the Arduino. This did not help.
Does someone have an idea why this is not working properly?
Thank you for any advice!
