Sorry for this dumb question, i have this code which is part of a very large code i have remove the unnecessary (imho) parts of the large code block and pasted relevant part.
One thing I think you're doing wrong, (unless you're using a Due), is that a literal that size, (15890000) should be suffixed with L or UL to indicate a 'long' or 'unsigned long' literal constant. In this case, L is sufficient.
ie 15890000L
If you don't do that, it's interpreted as a 16-bit int, and can only have a max value of 32767.
If using an Arduino Due, an int is 32-bit, but for UNO, Mega etc it's 16-bit.
@DrAzzy ,@UKHeliBob , yes I went up to seven and missed the 10 ,Thanks @OldSteve well this calculation is part of a slightly big code which contains the declaration portion as unsigned long and @aarg yes i have documented it properly.
