Float Problem
Hallo Zusammen
Ich will einen Floatwert (Temperaturwert) mit einem SIM800L Modul an meinen Webserver senden. Leider kann ich irgendwie nur int senden, aber keine floats. Wie kann ich erreichen, dass der Float trotzdem ankommt. Bsp: Ich sende Wert 20.6, erhalte aber 20. Wenn ich anstatt der Variable (x) die Zahl 20.6 direkt einsetze, kommt 20.6 an. Bitte helft mir. :slight_smile:
Code:
#include "SIM900.h"
#include <SoftwareSerial.h>
//#include "inetGSM.h"
//#include "sms.h"
//#include "call.h"
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to communicate with SIM900 through AT commands.
//InetGSM inet;
//CallGSM call;
//SMSGSM sms;
int numdata;
char inSerial[40];
int i=0;
float x = 4.3;
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0;        // will store last time LED was updated
// constants won't change :
const long interval = 10000;           // interval at which to blink (milliseconds)
  //Serial connection.
  Serial.println("GSM Shield testing.");
  //Start configuration of shield with baudrate.
  //For http uses is raccomanded to use 4800 or slower.
  if (gsm.begin(9600))
    Serial.println("\nstatus=READY");
  else Serial.println("\nstatus=IDLE");
     gsm.SimpleWriteln("AT+CIPSHUT");
   gsm.SimpleWriteln("AT+CSQ");
     gsm.SimpleWriteln("AT+CIPMUX=0");
    gsm.SimpleWriteln("AT+CSTT=\"gprs.swisscom.ch\",\"\",\"\"");
    delay(24000);
    gsm.SimpleWriteln("AT+CIICR");
      delay(4000);
      gsm.SimpleWriteln("AT+CIFSR");
      delay(4000);
       gsm.SimpleWrite("AT+CIPSTART=\"UDP\",\"");
     gsm.SimpleWrite("xx.xx-box.ch");
      gsm.SimpleWrite("\",");
       gsm.SimpleWriteln("8888");
       delay(10000);
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
      gsm.SimpleWriteln("AT+CIPSEND");
        gsm.SimpleWriteln(x);
       delay(100);
      inSerial[0]=0x1a;
     inSerial[1]='\0';
      gsm.SimpleWriteln(inSerial);
        delay(10);
       x = x + 1;
  serialhwread();
  //Read for new byte on NewSoftSerial.
  serialswread();
void serialhwread(){
  i=0;
  if (Serial.available() > 0){
    while (Serial.available() > 0) {
      inSerial[i]=(Serial.read());
      delay(10);
      i++;
    inSerial[i]='\0';
    if(!strcmp(inSerial,"/END")){
      Serial.println("_");
      inSerial[0]=0x1a;
      inSerial[1]='\0';
    //Send a saved AT command using serial port.
    if(!strcmp(inSerial,"TEST")){
      Serial.println("SIGNAL QUALITY");
    else{
      Serial.println(inSerial);
    inSerial[0]='\0';
void serialswread(){
  gsm.SimpleRead();
Hast du es schon mal als "char" versucht zu senden ?
Als char müsste es funktionieren, so sende ich meine Werte auch über GSM. Zwar als SMS, aber das sollte bei dir auch funktionieren.
Wie müsste ich mein Code abändern?
Funktioniert bei mir nicht, wenn ich float durch char ersetze.
Folgenden Code habe ich probiert:
//#include "sms.h"
//#include "call.h"
//InetGSM inet;
//CallGSM call;
//SMSGSM sms;
int numdata;
char inSerial[40];
int i=0;
char x = 4.3;
    delay(4000);
      delay(4000);
     gsm.SimpleWrite("xx.xxx-box.ch");
       delay(10000);
       delay(100);
      inSerial[0]=0x1a;
     inSerial[1]='\0';
        delay(10);
       x = x + 1;
  serialhwread();
  serialswread();
  i=0;
      delay(10);
      i++;
    inSerial[i]='\0';
      inSerial[0]=0x1a;
      inSerial[1]='\0';
    else{
    inSerial[0]='\0';
  gsm.SimpleRead();
Leider ohne Erfolg
du sollst nicht die Variablentype als char definieren, sondern die 20.6 in einen char array umwandeln und das array senden
Ich habe es mir mehreren Beispielcodes aus dem Internet probiert. Es funktioniert aber nicht. Könnt ihr mir helfen?
ElEspanol:
Sorry mein Fehler.
Ich habe mich falsch ausgedrückt. :wink:
Kannst du mir einen anderen Lösungsvorschlag machen?
Vorneweg: Ich habe keine praktische Erfahrung mit dem, was Du machst!
Ein Blick in die Bibliothek sagt mir, daß nur Zeiger auf Zeichenketten oder Intergerwerte übertragen werden (Datei SIM900.h):
void SimpleWriteln(char *comm);
void SimpleWriteln(char const *comm);
void SimpleWriteln(const __FlashStringHelper *pgmstr);
void SimpleWriteln(int comm);
Sollte bei Dir was anderes stehen, zeige den Link zu der von Dir benutzten Bibliothek.
Ich verwende diese Bibliothek, die du genannt hast. Wie kann ich nun trotzdem float Werte senden?
In der library definieren?
Definiere ein char array.
"Char meinArray[20];"
Und fülle das Array mit einem Text.
meinArray = "12.7";
Die 20 ist die maximale (-1) Anzahl Zeichen deines Strings.
So sollte es funktionieren.
Im übrigen sind das Grundlagen die du reichlich im Web findest.
HotSystems:
Könnte man auch char inSerial[40]; verwenden?
Super, es funktionert. Wie kann ich jedoch nun erreichen, dass zu meinem char bei jedem loop z.B 0.1 hinzugefügt wird?
agmue:
Sicher geht das auch, wenn der Name nicht anderweitig genutzt wird.
arduino_weather:
Na prima.
Ich würde da zuvor ein float per Schleife hochzählen und anschließend in einen String wandeln und danach dem Array übergeben.
Jetzt müsste man noch wissen, wie man das machen kann. Habe wenig Erfahrung mit char arrays. Wie müsste ich vorgehen?
arduino_weather:
Sorry, aber evtl. solltest du dich mal ein wenig in die Grundlagen einarbeiten.
Bisher waren das alles nur Grundlagenfragen.
Direkt hinzufügen kann ich die 0.1 ja nicht.
z. B bekomme ich einen Error, wenn ich folgendes versuche:
meinArray = meinArray + 0.1;
