hello, how can I convert byte array in to a float and back
For exapmle i have
float f=1.5;
to send it by Serial i wanna conwert it into a byte[4] array.
And back, by receiving byte[4] array — convert into a float.Текст "как есть" (без применения форматирования)
Describe the byte array, and explain the operation you have in mind.
A float value is stored in memory as an array of four bytes.
Look into using a ‘union’.
Do you want to convert each byte or do you want to cast 4 bytes to floating point value;
unsigned char ar[8];
// ... fill in ar from communication link
float f=ar[0]; // convert
float f=(float) &ar[0]; // cast == I typed (star) (float (star)) & // but the new forum removed the star symbol??
float f1=(float) &ar[4]; // cast == I typed (star) (float (star)) & // but the new forum removed the star symbol??
And I formatted as code like we used to do?
Im sorry its my first expirience of c++ coding, do u mean this function, that can return me float by array of 4 bytes?
float byteToFloat(byte bytesAsFloat[4]){ return *(float*) &bytesAsFloat[4]; }
Serial.write ((uint8_t *) &f,4);
union Test
unsigned long longNumber; //or float
byte longBytes[4];
Test num;
num. longNumber = 0x12345678;
Serial.println( num.longBytes[0], HEX);
Discourse supports the Markdown markup language. In Markdown, a single * adjacent to text is the syntax for italics:
https://www.markdownguide.org/basic-syntax/#italic
So instead of *, you got italicized text.
Unfortunately, this forum works differently in terms of creating code blocks. In the old SMF forum, we could click the </> button and then paste the code. But in this new Discourse-based forum you must do this:
- Paste the code into the post composition field
- Select the code you want to put in a code block.
- Click the
</>button.
You will now find that all the code has been indented by four spaces. This is the Markdown syntax for a code block:
https://www.markdownguide.org/basic-syntax/#code-blocks
Experienced users might actually find it easier to just manually add the markup for code blocks. You can use the old style BBCode if you prefer
[code]
[/code]
Or it's even faster to do it using Markdown fenced code blocks:
https://www.markdownguide.org/extended-syntax/#fenced-code-blocks
Just add three backticks (```) on the line before and after the code:
