Info:
I am trying to measure water flow with a flowsensor, when 600 litres of water went through the sensor it needs to shut a valve.
Problem:
The first code what I had only measured the flow and worked fine with the serial monitor, now I added the litre cap and also a reset button aswell as a valve. now I've done that my serial monitor already stops updating when it measures the smallest bit of flow...
Any Idea what I've done wrong in my code? it should only give a signal when it reaches a total of 600 litres..
My first code what worked with serial monitor but only measured flow:
byte statusLed = 13;
byte sensorInterrupt = 0; // 0 = digital pin 2
byte sensorPin = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
// Initialize a serial connection for reporting values to the host
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH); // We have an active-low LED attached
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
* Main program loop
if((millis() - oldTime) > 1000) // Only process counters once per second
// Disable the interrupt while calculating flow rate and sending the value to
// the host
detachInterrupt(sensorInterrupt);
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
unsigned int frac;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("L/min");
Serial.print("\t"); // Print tab space
// Print the cumulative total of litres flowed since starting
Serial.print("Output Liquid Quantity: ");
Serial.print(totalMilliLitres);
Serial.println("mL");
Serial.print(totalMilliLitres/1000);
Serial.print("L");
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
Insterrupt Service Routine
void pulseCounter()
// Increment the pulse counter
pulseCount++;
My code now what doesnt work properly anymore since I added the stuff listed above in my desc:
byte sensorPin = 2;
float calibrationFactor = 9.5;
float flowRate;
unsigned long totalLitres;
int procesklep = 4;
int resetknop = 7;
pinMode(procesklep, OUTPUT);
pulseCount = 0;
flowRate = 0.0;
totalLitres = 0;
oldTime = 0;
attachInterrupt(sensorInterrupt, sensorPin, FALLING);
if ((millis() - oldTime) > 1000) // Only process counters once per second
// the host
flowRate = ((300.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
oldTime = millis();
unsigned int frac;
Serial.print(totalMilliLitres / 1000);
Serial.print("L");
pulseCount = 0;
totalLitres = totalMilliLitres / 1000; //Transform total millilitres to total litres
if (totalLitres >= 600) { //If the total litres match the value of 600, then the "procesklep" must be closed.
digitalWrite(procesklep, HIGH);
else {
digitalWrite(procesklep, LOW);
if (resetknop == 1) { //Reset = Set every variable to 0
pulseCount = 0;
flowRate = 0.0;
totalLitres = 0;
oldTime = 0;
void pulseCounter()
pulseCount++;
Thanks in advance.
