You have the declaration for the runlights() function within the loop() function.
Here is the code formatted to show the problem
* PIR sensor tester
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
int buttonPin = 6; //choose the pin for the button
int tim = 120; //sets time for delays
int brightness = 0; // how bright the LED is
int fadeAmount = 1; // how many points to fade the LED by
int ledPin1 = 9;
int ledPin2 = 6;
int ledPin3 = 5;
int ledPin4 = 3;
int surroundPin = 11;
int fadespeed = 10;
int timeTravelSpeed = 80;
int timeTravelLength = 25;
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
pinMode(buttonPin, INPUT); //declare button as input
//Serial.begin(9600);
while (digitalRead(buttonPin) == LOW) //reads the button and uses this code
val = digitalRead(inputPin); // read input value
if (val == HIGH) // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
runlights(); //run the light show!
if (pirState == LOW)
// we have just turned on
//Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH)
// we have just turned of
//Serial.println("Motion ended!");
pirState = LOW;
void runlights() //*** function declaration is within the loop() function ***
//Speed up loops
for (int fadeIncrement = 20; fadeIncrement <= 100; fadeIncrement += 2)
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += fadeIncrement)
analogWrite(ledPin1, fadeValue);
delay(fadespeed);
for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= fadeIncrement)
delay(fadespeed);
analogWrite(ledPin1, 0);
analogWrite(ledPin2, fadeValue);
delay(fadespeed);
delay(fadespeed);
analogWrite(ledPin2, 0);
analogWrite(ledPin3, fadeValue);
delay(fadespeed);
delay(fadespeed);
analogWrite(ledPin3, 0);
analogWrite(ledPin4, fadeValue);
delay(fadespeed);
delay(fadespeed);
analogWrite(ledPin4, 0);
//time travel loops
for (int timetravel = 1; timetravel <= timeTravelLength; timetravel += 1)
//turn on surround lights
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 15)
analogWrite(surroundPin, fadeValue);
delay(fadespeed);
//Run time travel lights
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += timeTravelSpeed)
delay(fadespeed);
for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= timeTravelSpeed)
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
//fade out the surround lights
for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 15)
delay(fadespeed);
delay(500); //I suggest using this so it doesn't skip out of the next while loop if you hold the button a little too long
//insert your solid light code here
//once the button is pressed (==HIGH) it will stop looping and go to the next line
digitalWrite(ledpin1 HIGH);
delay(tim);
digitalWrite(ledpin1, LOW);
delay(tim);
digitalWrite(ledpin2, HIGH);
delay(tim);
digitalWrite(ledpin2, LOW);
delay(tim);
digitalWrite(ledpin3, HIGH);
delay(tim);
digitalWrite(ledpin3, LOW);
delay(tim);
digitalWrite(ledpin4, HIGH);
delay(tim);
digitalWrite(ledpin4, LOW);
delay(tim);
// set the brightness of leds:
analogWrite(ledPin1, brightness);
analogWrite(ledPin2, brightness);
analogWrite(ledPin3, brightness);
analogWrite(ledPin4, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255)
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(10);
