Hi looking for some one that can build me boards and supply software that enables the flysky i6x to display the following on the screen for Bait boats that i build at a reasonable cost for regular orders.
Display distance on screen
Display speed
Display signal strength
Board must recieve power from the speed control Bec
Control over the following required
Boat speed via speed control
Activate bait spinner we use either a servo or speed control
Drop bait buckets
Rudder
Lights on and off for 12v leds
Save home point and return on loss of signal.
Move post here:
thx
Could i have a bit more information please.
Are you using an existing flight controller ?
Does this unit sit alongside that controller.
For return to launch, is there an onboard GPS and if it is connected to the controller why not use that to return to launch.
Where is the display ? On the TX or on the boat.
Are you using the TX to guide the boat.
What triggers the spinners and bait release, is this coming from the TX ?
Hi not useing flight contoller .
The Tx controls the boat . Need a unit just to give me the gps information on screen.
Channel 1 servo ruddetr
channel2 spinner
ch3 speed control with bec
ch 4 traysystem
switch needs to be assigned for lights on and off 12v led
OK so the unit need to send data back to the TX and then the TX needs to be able to display that data somehow in the UI of the TX.
On the boat what are you using between the TX receiver and the controllers.
Define "reasonable cost for regular orders".
Just as an note: Get a Radiomaster T16S with EdgeTX, then you have that stuff already built in ... and you can customize the data display with LUA.
thx will also look at the option. We have over 1000 customers currently using the i6x so looking for cost afordable option for them.
servos plug into the reciever on the boat
1000 is a reasonable number of installations. I sent you a PM.
And how are you expecting the location of the boat to be displayed on your TX, does the TX already support NMEA data-steams to display lat/lon/heading/speed etc
Hi yes had a system from a supplier in Russia full autopilotthat made te bords and program for display on i6 x we just cant get it anymore due to sanctions. Need a suplier that knows i6x flysky and can supply end to end product
Check your PM ... or send me a PM ![]()
