Hi guys
I have put together a 24 hour clock with a Arduino UNO a Freetronics DMD and a RTC
Basically I am happy with the clock as it keeps pretty good time but I am not 100% happy with the font display showing the number 5 it just doesn't look right to me
I am using the Arial14.h font and the display of the number 5 is distorted. I have had a look through the Arial14.h file but I don't understand how the coding(?) works.
Would anyone like to point me in the right direction? Or suggest an alternative font?
I have tried Arial16 but it doesn't fit on a single DMD. I have included a photo of the clock display sorry about the quality but I had to place a sheet of paper over the display otherwise I couldn't get a clear enough picture.
I don't know the "Freetronics DMD" display. After I search it in the google, I found this page:
In this page there are a link to "Dot Matrix Display Driver library (software, example and demo program, install notes) on github"
In this resources I found a "Arial14.h". This to say that I don't know if is this file that you are talking about, but in mine, in the header comment it say "created with FontCreator". Did you try to find this application?
Thanks for replying have seen and I am using the Arial14.h from the website a do have used another file from another website uti have the same problem. Have tried editing the Arial14.h file but made a bigger mess. I will keep trying.
Take for example number 0. In ASCII, it's decimal value is 48. Now look in the font file, where it say "//48". Convert these hex numbers of this line, into binary, using the Windows calculator or whatever.
Thanks for your help and the file, it works perfectly.
I will have to get the uni books out again as I haven't touched bin/hex/ASCII in 25 years and see if I can create or modify font files.
Anyway I have attached a picture of the new improved clock that will go on my radio shack wall
I used one of the applications of the reply #1. I send you the file that the application give me. If you change "by hand" the 96 characters inside one of those files you will have work for 2 weeks, or so, and you will end with a "piece of garbage".
