For ESP32: Using Arduino IoT-cloud LOCALLY with Arduino-IDE
Hello,
I would like to use the cloud-functionality for accessing my devices from anywhere over internet while I want to do all the developping locally on the locally started Arduino-IDE.exe.
The Webeditor offers to download the sketch as a zip-file.
the additional *.h-file thingProperties.h
has two includes
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
I looked up the library-manager if I can find these libraries
The library-manager says
supported boards are MKRGSM, MKR1000, Wifi101
The GiPo says
WiFi: MKR 1000, MKR WiFi 1010, Nano 33 IoT, Portenta H7, ESP8266
But inside Arduino IoT there is a tutorial
that claims that ESP32 is supported.
So where can I get the two include-files
that fit to the ESP32?
best regards Stefan
Yes, but note that the support is considered do be at an experimental state at this time.
Just install them from Library Manager. They are the ones you're looking at.
Make sure to fill in your credentials in the arduino_secrets.h tab of your sketch.
I am also facing the same problem when I tried compiling the code after installing ArduinoIoTCloud. I am getting error
Multiple libraries were found for "WiFi.h"
Used: C:\Users\hp\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
Not used: C:\Users\hp\Documents\Arduino\libraries\WiFiNINA
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Using library ArduinoIoTCloud at version 1.0.2 in folder: C:\Users\hp\Documents\Arduino\libraries\ArduinoIoTCloud
Using library Arduino_ConnectionHandler at version 0.6.4 in folder: C:\Users\hp\Documents\Arduino\libraries\Arduino_ConnectionHandler
Using library WiFi at version 1.0 in folder: C:\Users\hp\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
Using library Arduino_DebugUtils at version 1.1.0 in folder: C:\Users\hp\Documents\Arduino\libraries\Arduino_DebugUtils
Using library WiFiClientSecure at version 1.0 in folder: C:\Users\hp\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFiClientSecure
Using library ArduinoMqttClient at version 0.1.5 in folder: C:\Users\hp\Documents\Arduino\libraries\ArduinoMqttClient
exit status 1
Error compiling for board DOIT ESP32 DEVKIT V1.
I tried changing the versions one after other still I could not move forward.
In fact my attempt to connect ESP32 in cloud editor failed with no clear reason. I have a ESP32 DEVKITV1
Any help plz?
regards
We will need to see the full error output. You have omitted the part that provides the cause of the error.
Please do this:
  1. When you encounter an error, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
  2. Open a forum reply here by clicking the Reply button.
  3. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  4. Press Ctrl+V. This will paste the compilation output into the code block.
  5. Move the cursor outside of the code block markup before you add any additional text to your reply.
  6. Click the Reply button to post the output.
With the Arduino IDE 2.0 you can pull an IoT Cloud sketch locally with just one button:
Make sure you get the latest build of the Arduino IDE 2.0. Also, with a single click you can re-upload your sketch to the cloud so that you always have a backup.
