A for-loop statement is available in most imperative programming languages. Even ignoring minor differences in syntax there are many differences in how these statements work and the level of expressiveness they support. Generally, for-loops fall into one of the following categories:
Traditional for-loops
The for-loop of languages like ALGOL, Simula, BASIC, Pascal, Modula, Oberon, Ada, Matlab, Ocaml, F#, and so on, requires a control variable with start- and end-values and looks something like this:
for i = first to last do statement
(* or just *)
for i = first..last do statement
Depending on the language, an explicit assignment sign may be used in place of the equal sign (and some languages require the word int even in the numerical case). An optional step-value (an increment or decrement ≠ 1) may also be included, although the exact syntaxes used for this differs a bit more between the languages. Some languages require a separate declaration of the control variable, some do not.
Another form was popularized by the C programming language. It requires 3 parts: the initialization, the condition, and the afterthought and all these three parts are optional.[1]
The initialization declares (and perhaps assigns to) any variables required. The type of a variable should be same if you are using multiple variables in initialization part. The condition checks a condition, and quits the loop if false. The afterthought is performed exactly once every time the loop ends and then repeats.
Here is an example of the traditional for-loop in Java.
// Prints the numbers 0 to 99 (and not 100), each followed by a space.
for (int i=0; i<100; i++)
System.out.print(i);
System.out.print(' ');
System.out.println();
Iterator-based for-loops
Main article: Foreach loop
This type of for-loop is a generalisation of the numeric range type of for-loop, as it allows for the enumeration of sets of items other than number sequences. It is usually characterized by the use of an implicit or explicit iterator, in which the loop variable takes on each of the values in a sequence or other data collection. A representative example in Python is:
for item in some_iterable_object:
do_something()
do_something_else()
Where some_iterable_object is either a data collection that supports implicit iteration (like a list of employee's names), or may in fact be an iterator itself. Some languages have this in addition to another for-loop syntax; notably, PHP has this type of loop under the name for each, as well as a three-expression for-loop (see below) under the name for.
Vectorised for-loops
Some languages offer a for-loop that acts as if processing all iterations in parallel, such as the for all keyword in FORTRAN 95 which has the interpretation that all right-hand-side expressions are evaluated before any assignments are made, as distinct from the explicit iteration form. For example, in the for statement in the following pseudocode fragment, when calculating the new value for A(i), except for the first (with i = 2) the reference to A(i - 1) will obtain the new value that had been placed there in the previous step. In the for all version, however, each calculation refers only to the original, unaltered A.
for i := 2 : N - 1 do A(i) := [A(i - 1) + A(i) + A(i + 1)] / 3; next i;
for all i := 2 : N - 1 do A(i) := [A(i - 1) + A(i) + A(i + 1)] / 3;
The difference may be significant.
Some languages (such as FORTRAN 95, PL/I) also offer array assignment statements, that enable many for-loops to be omitted. Thus pseudocode such as A := 0; would set all elements of array A to zero, no matter its size or dimensionality. The example loop could be rendered as
A(2 : N - 1) := [A(1 : N - 2) + A(2 : N - 1) + A(3 : N)] / 3;
But whether that would be rendered in the style of the for-loop or the for all-loop or something else may not be clearly described in the compiler manual.
Compound for-loops
Introduced with ALGOL 68 and followed by PL/I, this allows the iteration of a loop to be compounded with a test, as in
for i := 1 : N while A(i) > 0 do etc.
That is, a value is assigned to the loop variable i and only if the while expression is true will the loop body be executed. If the result were false the for-loop's execution stops short. Granted that the loop variable's value is defined after the termination of the loop, then the above statement will find the first non-positive element in array A (and if no such, its value will be N + 1), or, with suitable variations, the first non-blank character in a string, and so on.
