FOR loop in loop slows down function millis() How to avoid it?
Regards
I have this problem, I have simulated a sine wave using the for loop and the sin() function, inside the void loop, I am showing it on a 1.8" tft screen, but I noticed when printing by serial the millis() function slows down , the function of this code is to execute and simulate the wave all the time in the loop and display it on the tft screen. How could I replace the for loop and use another way to prevent time from slowing down. Thanks
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#define TFT_DC 8
#define TFT_CS 10
#define TFT_RST  -1
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
float j = 2 * 3.1416 / 360 ;
byte n = 1 ;
byte fase = 0 ;
  tft.initR(INITR_GREENTAB); //
  tft.fillScreen(ST7735_BLACK);
  tft.setRotation(3);
  for ( long  i = 0 ; i < 2200; i++)
    float y =  60 - sin( n * i * j - fase) * 10 ;
    float x =  i * 55 / 700 ;
    tft.drawCircle(x, y, 1, ST7735_WHITE);
  Serial.println(millis()); //  shows slow time not according
Let the loop() function do what its name implies
hello, the for loop makes it graph the wave if I remove it, it won't, I have investigated that there is a way to create it using a lookup table but I don't know how to implement it
Despite the time used to process 2200 floats, the millis() counter isn’t slowed down.
Your using 1970s serial speed, which more than likely will fill the tx buffer - then have to wait as it trickles out at ~1000 chars a second.
As suggested, a whole rewrite - to use loop() effectively, and pushing Serial.begin up to a higher speed will help.
You are not using fase to remove byte fase = 0 ; and - fase
unnecessarily large variable. an int will hold 2200 for half the cost
given i is an integer, this expression is entirely integer math and will never contain any digits to the right of the decimal place.
Use a baudrate of minimum 115200.
Depending on your microcontrollers clock beeing maybe 48 MHz or even more you can go up to 1 Mbaud or 2 MBaud
void loop() is looping
and non-blocking timing means that the only loop that is looping is void loop() itself
You can write code that does the same thing as a for-loop only with if-conditions.
function loop() itself is looping and will make your variable count up the same way as the for-loop does
Again depending on your microcontroller if your µC has enough RAM to hold all the values that you are calculating you could calculate all the values in function setup store the values in an array and then iterate through the array by incrementing the array-inde
best regards Stefan
