I'm trying write a piece of code that enables setting digital pins high or low over serial port (Max/MSP). I used two 'for' loops to loop through an array containing the pin numbers 0-13 to set them to output mode and to check whatever int is coming from the serial (between 0 and 13). The second loop doesn't work, I can't set any of the pins high. Where did I go wrong?
int pinCount = 14;
int digiPins[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13};
int thisPin;
for (int thisPin = 0; thisPin < pinCount; thisPin++){
pinMode(digiPins[thisPin], OUTPUT);
if (Serial.available() > 0){
// read the byte, convert from ASCII character '5' for example to 0x05, check ASCIItable.com for the characters
thisPin = Serial.read() - 48; // subtract 48 if pins are 0-9.
digitalWrite (digiPins[thisPin], HIGH); // set the pin high
delay (100); // hold it high for 1/10th of a second?
digitalWrite (digiPins[thisPin], LOW); // and back low.
Have to complicate things more if want to accept 2 digits, like 02 thru 13, or 1 or 2 digits. If first digit is 2-9, there is no nd digit. If first digit is 1, then it may be 10,11,12 ... 19.
Checking the pins with a scope but they don't seem to change their state (from low to high). Here's the full code:
int pinCount = 14;
int digiPins[] = {
int thisPin;
delay (1000); // hold it high for 1/10th of a second?
delay(1);
int digiPins[] = {
0,1,2,3,4,5,6,7,8,9,10,11,12,13}; << 0, 1 are the serial port pins - don't include them here
int thisPin;
for (int thisPin = 0; thisPin < pinCount; thisPin++){ << 0,1 are the Serial port pins - don't include them here.
Serial.print (thisPin); <<< add this print here, confirm what pin you are trying to access
Put an "if" there, since going outside the bounds of an array may cause a crash. Also just use '0' rather than 48, looks nicer. eg.
thisPin = Serial.read() - '0';
if (thisPin >= 0 && thisPin <= 9)
delay (1000); // hold it high for one second
Plus, this method just won't work with pins 10 onwards. You need to do more serial reads.
int pinCount = 14;
int digiPins[] = {
int thisPin;
delay(1);
Note I used the higher baud rate, which is my habit.
alkopop79: Plus, this method just won't work with pins 10 onwards. You need to do more serial reads.
What do you exactly mean?
Well you are doing a single Serial.read. How do you suppose "10" is going to fit into one byte?
The digits 10,11,12,13 ... are two characters. '1', '0', and '1', '1', etc.
So you have to do 2 reads and put the results together so that
digiPins[thisPin]
will work on pin 10, 11, 12, etc.
Or use a different single character to represent pins 10,11,12, etc.
perhaps A =10, B=11, C=12, D=13, E=14, F=15.
Still doesn't work, tired it with Max/MSP and the Arduino IDE serial monitor. I can see the RX led blinking but the pins won't go high.
int pinCount = 12;
int digiPins[] = {
int thisPin;
Serial.println(thisPin);
delay(1);
Have this start at 2:
"perhaps A =10, B=11, C=12, D=13, E=14, F=15.
You mean store symbols in the array instead of ints?"
No, I chose letters because they are hexadecimal values.
So your array could consist of {2,3,4,5,6,7,8,9,10,11,12,13};
then do Nick's test for whatever characters you decide to use, such as 'A' thru 'F'
int incomimgPin = Serial.read();
Serial.println(incomingPin);
// test for range 2-9
thisPin = incomingPin - 48;
// test for range A-F
thisPin = incomingPin - 65 + 10;
if (thisPin >= 10 && thisPin <= 15)
Why, oh why do I get this error even if incomingPin is declared before void setup????: serial_tester_thingy_2:17: error: 'incomingPin' was not declared in this scope
(moderator - need to use the # sign above - results in [ code ] paste_your_code [ / code ] (without the spaces) )
int pinCount = 12;
int digiPins[] = {
int thisPin;
//int incomimgPin; << oops - incoming mis-spelled
int incomimgPin = Serial.read(); << mis-spelled incoming here too
delay(1);
