Formula for Outputting Wet Bulb temp from Temp and RH
Ok, I have a dht11 which gives me Temperture and Relative Humidity.
What i'm trying to do is have an arduino display current WET BULB temp on a display. I can get it to display Temp and RH, but thats as far as I've gotten.
I found an old post with some math, but I need help turning that into something that I can put into my code.
here is the math I found online;
On a range Tdry bulb=15..40[deg C] and rh=10...90[%]you can calculate the Twet bulb[degC] at P=1006[mbar](=755 Torr)with max relative error~6% with an approximative polynomial model that you can put in a cells. For lower Tdry and rh the relative error will be higher.
Twet bulb= ATdry + Brh + CTdry^2 + Drh^2+ ETdryrh + F
where
A=5,391260E-01
B=1,047837E-01
C=-7,493556E-04
D=-1,077432E-03
E=6,414631E-03
F=-5,151526E+00
Anyone able to break this down for me and help me out?
Thanks in advance...
What do you need help with? * is multiplication, and is done with the same symbol in C++. ^2 means squared, which is equivalent to x * x.
float Twet= A*Tdry + B*rh + C*Tdry*Tdry + D*rh*rh+ E*Tdry*rh + F ;
MarkT:
Excellent, now I just to learn how to put the values of a-f into some sort of variable so this function can read them.
Cheers, and thanks for all your helps far. I am a newbie when it comes to C and more so when it comes to arduino.
M
Ok, I think I have it now.
Maybe someone could check my code and see if I did it right?
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
int read_LCD_buttons()
 adc_key_in = analogRead(0);      // read the value from the sensor
 // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
 // we add approx 50 to those values and check to see if we are close
 if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
 // For V1.1 us this threshold
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 250)  return btnUP;
 if (adc_key_in < 450)  return btnDOWN;
 if (adc_key_in < 650)  return btnLEFT;
 if (adc_key_in < 850)  return btnSELECT;
 return btnNONE;  // when all others fail, return this...
#define DHT11_PIN 0      // ADC0  Define the ANALOG Pin connected to DHT11 Sensor
int temp1[3];                //Temp1, temp2, hum1 & hum2 are the final integer values that you are going to use in your program.
int temp2[3];                // They update every 2 seconds.
int hum1[3];
int hum2[3];
byte read_dht11_dat()
  byte i = 0;
  byte result=0;
  for(i=0; i< 8; i++){
    while(!(PINC & _BV(DHT11_PIN)));  // wait for 50us
    delayMicroseconds(30);
    if(PINC & _BV(DHT11_PIN))
      result |=(1<<(7-i));
    while((PINC & _BV(DHT11_PIN)));  // wait '1' finish
  return result;
long dht11delay_previousMillis = 0;        // will store last time LED was updated
long dht11delay_interval = 1000;           // dht11delay_interval at which to blink (milliseconds)
  DDRC |= _BV(DHT11_PIN);
  PORTC |= _BV(DHT11_PIN);
  delay(100);
  unsigned long dht11delay_currentMillis = millis();
  if(dht11delay_currentMillis - dht11delay_previousMillis > dht11delay_interval) {
    // save the last time you blinked the LED
    dht11delay_previousMillis = dht11delay_currentMillis;
    byte dht11_dat[5];
    byte dht11_in;
    byte i;
    // start condition
    // 1. pull-down i/o pin from 18ms
    PORTC &= ~_BV(DHT11_PIN);
    delay(18);
    delayMicroseconds(40);
    DDRC &= ~_BV(DHT11_PIN);
    dht11_in = PINC & _BV(DHT11_PIN);
    if(dht11_in){
      Serial.println("dht11 start condition 1 not met");
      return;
    delayMicroseconds(80);
    if(!dht11_in){
      Serial.println("dht11 start condition 2 not met");
      return;
    // now ready for data reception
    for (i=0; i<5; i++)
      dht11_dat[i] = read_dht11_dat();
    byte dht11_check_sum = dht11_dat[0]+dht11_dat[1]+dht11_dat[2]+dht11_dat[3];
    // check check_sum
    if(dht11_dat[4]!= dht11_check_sum)
      Serial.println("DHT11 checksum error");
    temp1[0]=dht11_dat[2];
    temp2[0]=dht11_dat[3];
    lcd.begin(16,2);
    lcd.setCursor(0,0);
    lcd.print("Tmp:");
    lcd.print(temp1[0]);
    lcd.print("c ");
    lcd.print("WB:");
    lcd.print(5.391260E-01*temp1[0] + 1.047837E-01*hum1[0] + -7.493556E-04*hum1[0]*hum1[0] + -1.077432E-03*hum1[0]*hum1[0] + 6.414631E-03*temp1[0]*hum1[0] + 5.151526E+00);
    hum1[0]=dht11_dat[0];
    hum2[0]=dht11_dat[1];
    lcd.setCursor(0,1);
    lcd.print("Hum:");
    lcd.print(hum1[0]);
    lcd.print("%");
// END OF CODE
michaeli:
MarkT:
variables not needed, indeed they are constant(!)
#define A 0.539126
#define B 0.1047837
