FreeRTOS task issue using ESP32
Hello, everyone.
I am working on a project that would require multi-tasking so I am using the FreeRTOS library. The main functionality of my project is to run a motor and run a six hours countdown timer, there are also some variables that I want to send to Firebase and display on Nextion . I've successfully run the motor, sending data to Firebase and the Nextion display also worked for the motorRun task. The problem is, the countdown timer did not work. Please help me to solve this problem.
Here is my code:
#include <FirebaseESP32.h>
#include <WiFi.h>
#include <WiFiManager.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
String timeSet, patientName, patientID, timeNow, datas, fluidType, volumeSet;
#define FIREBASE_HOST "xxx"
#define FIREBASE_AUTH "xxx"
#define RX 40
#define TX 41
const int motorPin1 = 26;
const int motorPin2 = 27;
int motorEn = 0;
FirebaseData firebaseData;
FirebaseJson json;
void timer6hr(void *parameters)
  int remainingTime = 6 * 60 * 60;
  while (remainingTime > 0)
    Serial.print("t8.txt=\"" + String(remainingTime / 3600) + ":" + String((remainingTime % 3600) / 60) + ":" + String(remainingTime % 60) + "\"");
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    Firebase.setString(firebaseData, "Users/" + patientName + "/duration", String(remainingTime / 3600) + ":" + String((remainingTime % 3600) / 60) + ":" + String(remainingTime % 60));
    vTaskDelay(1000 / portTICK_PERIOD_MS);
    remainingTime--;
void motorRun(void *parameters)
  unsigned long startTime = millis();
  float volumeNow = 0.0;
  Firebase.setString(firebaseData, "Users/" + patientName + "/volume", String(volumeNow));
  while (millis() - startTime < 6 * 60 * 60 * 1000) {
    digitalWrite(motorPin1, HIGH);
    digitalWrite(motorPin2, LOW);
    digitalWrite(motorEn, 255);
    vTaskDelay(60000 / portTICK_RATE_MS);
    volumeNow += 4.3;
    Serial.print("t10.txt=\"" + String(volumeNow) + " " + "\"");
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    digitalWrite(motorPin1, LOW);
    digitalWrite(motorEn, 0);
    vTaskDelay(180000 / portTICK_RATE_MS);
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorEn, OUTPUT);
  wifiFirebase();
  vTaskDelay(2000 / portTICK_PERIOD_MS);
  Serial.println("Ready!");
  unsigned long lastCheckTime = 0;
  if (Serial.available() > 0) {
    if (millis() - lastCheckTime > 1000 ) {
      datas = Serial.readString();
      if (datas == "stop") {
        Serial.println("Restarting ESP32...");
        Serial.print("t10.txt=\"" + String(0.0) + " " + "\"");
        Serial.write(0xff);
        Serial.write(0xff);
        Serial.write(0xff);
        ESP.restart();
      else if (datas.startsWith("YN")) {
        patientName = datas.substring(2);
        Serial.print("Name:");
        Serial.print(patientName);
      else if (datas.startsWith("ID")) {
        patientID = datas.substring(2);
        Serial.print("ID:");
        Serial.print(patientID);
        Firebase.setString(firebaseData, "Users/" + patientName + "/id", patientID);
      else if (datas.startsWith("VOL")) {
        volumeSet = datas.substring(3);
        Serial.print("Volume Set:");
        Serial.print(volumeSet);
        Firebase.setString(firebaseData, "Users/" + patientName + "/volumeSet", volumeSet);
      else if (datas.startsWith("FL")) {
        fluidType = datas.substring(2);
        Serial.print("Fluid Type:");
        Serial.print(fluidType);
        Firebase.setString(firebaseData, "Users/" + patientName + "/fluid", fluidType);
      else if (datas.startsWith("TM")) {
        checkTimeSet();
        lastCheckTime = millis();
void checkTimeSet() {
  timeSet = datas.substring(2);
  Firebase.setString(firebaseData, "Users/" + patientName + "/timeSet", timeSet);
  if (timeSet == "6") {
    xTaskCreate(
      motorRun,
      "Task 2: motorRun",
      80000,
      NULL,
      1,
      NULL
    xTaskCreate(
      timer6hr,
      "Task 1: timer6hr",
      60000,
      NULL,
      1,
      NULL
void wifiFirebase() {
  WiFiManager wm;
  WiFi.mode(WIFI_STA);
  bool res;
  res = wm.autoConnect("wifiName");
  if (!res) {
    Serial.println("Failed to connect");
  else {
    Serial.println("connected...yeey :)");
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
What should I change in my code?
Thank you in advance for your responses! Hope you have a wonderful day!
The way you wrote the code is all wrong. So I do not have to spend the next 3 or 4 hours rewritting your code, I'll post a properlly structured code using freeRTOS on a ESP32 that you can use as a model to rewrite your code.
I share with you a properly structured use of freeRTOS on a ESP32.
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection info for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
WiFiClient      wifiClient; // do the WiFi instantiation thing
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time       rtc;
#define evtWaterCactus      ( 1 << 0 ) // declare an event
#define evtADCreading0      ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
SemaphoreHandle_t sema_WaterCactus;
QueueHandle_t xQ_RemainingMoistureMQTT;
QueueHandle_t xQ_RM;
QueueHandle_t xQ_Message;
esp_timer_handle_t oneshot_timer; //veriable to store the hardware timer handle
const int payloadSize = 150;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;////
int    mqttOK = 0;
bool   TimeSet = false;
//bool   manualPumpOn = false;
void IRAM_ATTR oneshot_timer_callback( void* arg )
  BaseType_t xHigherPriorityTaskWoken;
  xEventGroupSetBitsFromISR( eg, evtWaterCactus, &xHigherPriorityTaskWoken );
} //void IRAM_ATTR oneshot_timer_callback( void* arg )
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
  memcpy( x_message.payload, payload, length );
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  x_message.topic.reserve( payloadSize );
  xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
  xQ_RemainingMoistureMQTT = xQueueCreate( 1, sizeof(float) ); // sends a queue copy
  xQ_RM = xQueueCreate( 1, sizeof(float) );
  eg = xEventGroupCreate(); // get an event group handle
  sema_mqttOK =  xSemaphoreCreateBinary();
  sema_WaterCactus = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  xSemaphoreGive( sema_WaterCactus );
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pull_down_en = GPIO_PULLDOWN_ENABLE; // enable pull down
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) | (1ULL << GPIO_NUM_18) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  io_cfg = {}; //set configuration structure back to default values
  io_cfg.mode = GPIO_MODE_OUTPUT;
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_4) | (1ULL << GPIO_NUM_5) | (1ULL << GPIO_NUM_19)  ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
  gpio_set_level( GPIO_NUM_5, LOW); // deenergize valve
  gpio_set_level( GPIO_NUM_19, LOW); // deenergize valve
  // set up A:D channels  https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
  // https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html?highlight=hardware%20timer High Resoultion Timer API
  esp_timer_create_args_t oneshot_timer_args = {}; // initialize High Resoulition Timer (HRT) configuration structure
  oneshot_timer_args.callback = &oneshot_timer_callback; // configure for callback, name of callback function
  esp_timer_create( &oneshot_timer_args, &oneshot_timer ); // assign configuration to the HRT, receive timer handle
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fPublish, "fPublish", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fReadAD, "fReadAD", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 70000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
} //void setup()
// check gpiopin for cactus is present
// water cactus upon detection
// wait 30 days to water the cactus again
// to water
// let fDoMoistureDetector know of motor use.
// open valve
// run motor for 10 times each time for 10 seconds 5 minutes apart
// after sequence is done release fDoMoistureDetector
// start counting 30 days
void fWaterCactus( void * parameter )
  uint32_t microSecondsInADay = 86400000000;
  uint32_t DayCount           = 29;
  uint64_t pastTime           = esp_timer_get_time();
  uint32_t WaterTimeCount     = 0;
  //GPIO_NUM_18 is cactus detect pin.
  for (;;)
    if ( gpio_get_level( GPIO_NUM_18 ) )
      if ( (esp_timer_get_time() - pastTime) >= microSecondsInADay )
        DayCount++;
      if (DayCount == 30 )
        xSemaphoreTake( sema_WaterCactus, portMAX_DELAY );// stops the other task from running the pump.
        //water cactus
        while ( WaterTimeCount < 10 )
          gpio_set_level( GPIO_NUM_19, HIGH); // energize/open valve
          WaterPump0_on();
          // one minute of uS = 60000000
          esp_timer_start_once( oneshot_timer, 60000000 );
          xEventGroupWaitBits (eg, evtWaterCactus, pdTRUE, pdTRUE, portMAX_DELAY ); // event will be triggered by the timer expiring, wait here for the 280uS
          WaterPump0_off();
          gpio_set_level( GPIO_NUM_19, LOW); // deenergize/close valve
          WaterTimeCount++;
        WaterTimeCount = 0;
        DayCount = 0; // reset day couunt
      DayCount = 0;
  } // for(;;)
  vTaskDelete( NULL );
void fReadAD( void * parameter )
  float    ADbits = 4096.0f;
  float    uPvolts = 3.3f;
  float    adcValue_b = 0.0f; //plant in yellow pot
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
  float    WetValue = 1.07f; // value found by putting sensor in water
  float    DryValue = 2.732f; // value of probe when held in air
  float    Range = DryValue - WetValue;
  float    RemainingMoisture = 100.0f;
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  for (;;)
    xEventGroupWaitBits (eg, evtADCreading0, pdTRUE, pdTRUE, portMAX_DELAY ); //
    adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
    adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
    KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
    TimePastKalman = esp_timer_get_time(); // time of update complete
    RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture =  1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
    xQueueOverwrite( xQ_RM, (void *) &RemainingMoisture );
    //log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
void fPublish( void * parameter )
  for (;;)
    if ( xQueueReceive(xQ_RemainingMoistureMQTT, &RemainingMoisture, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
  } // for (;;)
} //void fPublish( void * parameter )
void WaterPump0_off()
  gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
void WaterPump0_on()
  gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 12;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 5000; //delay for mS
  for (;;)
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fDoMoistureDetector1( void * parameter )
  //wait for a mqtt connection
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  int      TimeToPublish = 5000000; //5000000uS
  int      TimeForADreading = 100 * 1000; // 100mS
  uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
  uint64_t TimeADreading   = esp_timer_get_time();
  const TickType_t xFrequency = 10; //delay for 10mS
  float    RemainingMoisture = 100.0f; //prevents pump turn on during start up
  bool     pumpOn = false;
  uint64_t PumpOnTime = esp_timer_get_time();
  int      PumpRunTime = 11000000;
  uint64_t PumpOffWait = esp_timer_get_time();
  uint64_t PumpOffWaitFor = 60000000; //one minute
  float    lowMoisture = 23.0f;
  float    highMoisture = 40.0f;
  for (;;)
    //read AD values every 100mS.
    if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
      xEventGroupSetBits( eg, evtADCreading0 );
    xQueueReceive(xQ_RM, &RemainingMoisture, 0 ); //receive queue stuff no waiting
    //read gpio 0 is water level good. Yes: OK to run pump : no pump off.   remaining moisture good, denergize water pump otherwise energize water pump.
    if ( RemainingMoisture >= highMoisture )
      WaterPump0_off();
    if ( !pumpOn )
      log_i( "not pump on ");
      if ( gpio_get_level( GPIO_NUM_0 ) )
        if ( RemainingMoisture <= lowMoisture )
          //has one minute passed since last pump energize, if so then allow motor to run
          if ( (esp_timer_get_time() - PumpOffWait) >= PumpOffWaitFor )
            gpio_set_level( GPIO_NUM_5, HIGH); //open valve
            WaterPump0_on();
            log_i( "pump on " );
            pumpOn = !pumpOn;
        //xSemaphoreGive( sema_RemainingMoisture );
        log_i( "water level bad " );
        WaterPump0_off();
        gpio_set_level( GPIO_NUM_5, LOW); //denergize/close valve
         pump goes on runs for X seconds then turn off, then wait PumpOffWaitTime before being allowed to energize again
      if ( (esp_timer_get_time() - PumpOnTime) >= PumpRunTime )
        log_i( "pump off " );
        WaterPump0_off(); // after 5 seconds turn pump off
        pumpOn = !pumpOn;
    // publish to MQTT every 5000000uS
    if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
      xQueueOverwrite( xQ_RemainingMoistureMQTT, (void *) &RemainingMoisture );// data for mqtt publish
      TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector1()
void fDoMoistureDetector( void * parameter )
    vTaskDelay( 250 );
  for (;;)
      WaterPump0_off();
    if ( !pumpOn )
            WaterPump0_on();
            pumpOn = !pumpOn;
        WaterPump0_off();
        pumpOn = !pumpOn;
}// end fDoMoistureDetector()
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; // 250mS
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  // create client ID from mac address
  byte mac[5];
  int count = 0;
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]);
  log_i( "connect to mqtt as client %s", clientID );
    MQTTclient.disconnect();
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
    count++;
    if ( count == 5 )
      ESP.restart();
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      if ( px_message.topic == topicOK )
        mqttOK = 0; // clear mqtt ok count
      if ( !TimeSet )
        String temp = "";
        temp = px_message.payload[0];
        temp += px_message.payload[1];
        temp += px_message.payload[2];
        temp += px_message.payload[3];
        int year =  temp.toInt();
        temp = "";
        temp = px_message.payload[5];
        temp += px_message.payload[6];
        int month =  temp.toInt();
        temp = "";
        temp = px_message.payload[8];
        temp += px_message.payload[9];
        int day =  temp.toInt();
        temp = "";
        temp = px_message.payload[11];
        temp += px_message.payload[12];
        int hour =  temp.toInt();
        temp = "";
        temp = px_message.payload[14];
        temp += px_message.payload[15];
        int min =  temp.toInt();
        rtc.setTime( 0, min, hour, day, month, year );
        log_i( "%s  ", rtc.getTime() );
        TimeSet = true;
      // manual pump control
      //      if ( str_eTopic == topicPumpState )
      //        if ( String(strPayload) == "off" )
      //          WaterPump0_off();
      //          manualPumpOn = false;
      //        if ( String(strPayload) == "on" )
      //          WaterPump0_on();
      //          manualPumpOn = true;
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
Hello, thank you for your reply. I will try to understand it
