system
1
Hey,
I've a Question about the combination of the
#include <FreeRTOS_ARM.h>
and
#include <SD.h>
Libraries. My problem is that I can't read or write to the SD Card after
I startet my tasks with
vTaskStartScheduler();
Maybe somebody know this problem or some solution for that?
Before I start my tasks the SD Card read/write works fine.
Thanks for your Support:-)
system
2
Yeah I've solved my problem!
You have to disable the interrupts before you read or write from/to an SD card
noInterrupts();
writeToSD();
interrupts();
An other problem can be the task Stack_Size.
xTaskCreate(Thread_1, NULL, Stack_Size , pvParameter, 3, NULL);
Hola puedes, compartir el código sobre el que trabajaste, tengo el mismo problema. Gracias
