FREQUENCY COUNTER FIX
MENTIONED BELLOW IS MY PROGRAM FOR FREQUENCY COUNTER USING INT MAIN() FUNCTION FREQUENCY COUNTING IS GOOD BUT NOT ABLE TO INSERT OTHER FEATURES IN IT AND FACING MANY ISSUES WHILE HANDELING THAT....
I TRIED IT CONVERTING IT INTO VOID SETUP AND VOID LOOP FUNCTION FORM BUT I AM NOT GETTING THE CORRECT FREQUENCY CAN ANYBODY HELP ME OUT IN THIS'
volatile uint16_t   timerOverflow   = 0;    // Timer1 Overflows
volatile uint16_t   Start= 0, End = 0;      //
volatile uint16_t update1 = 0;                 //  Flag
volatile uint16_t count = 0;
double freq = 0.0, freq1 = 0.0;
void InitTimer1(void)
  TCNT1=0;                         //SETTING INTIAL TIMER VALUE
  TCCR1B|=(1<<ICES1);              //SETTING FIRST CAPTURE ON RISING EDGE ,(TCCR1B = TCCR1B | (1<<ICES1)
  TIMSK1|=(1<<ICIE1)|(1<<TOIE1);   //ENABLING INPUT CAPTURE AND OVERFLOW INTERRUPTS
void StartTimer1(void)
  TCCR1B|=(1<<CS10);              //STARTING TIMER WITH PRESCALER 1
  sei();                          //ENABLING GLOBAL INTERRUPTS
ISR (TIMER1_CAPT_vect)
 static uint8_t flag = 1;
 if(update1)
   return;
 if(flag)
   Start       = ICR1;     //Read value counter
   timerOverflow = 0;
   flag      = 0;
   End     =   ICR1;
   update1    =  1;
     flag    =   1;
ISR(TIMER1_OVF_vect )
 timerOverflow++;
int main(void)
 pinMode(8, INPUT);
 digitalWrite(8,HIGH);
 InitTimer1();                        //CALLING FUNCTION INITTIMER1 TO INITIALIZE TIMER 1
 StartTimer1();
 Serial.begin(57600);
 while(1)
     if(update1)
         freq = ((timerOverflow * 65536) + End - Start);
         freq1 = 16000000/freq;
         Serial.println(freq1);
         update1=0;
         timerOverflow=0;                        //CLEARING OVERFLOW COUNTERS
         ICR1=0;
         Start=0;
         End=0;
         TCNT1 = 0;
Please post your attempt at using the standard setup() and loop() form of program, using code tags when you do, and PLEASE STOP SHOUTING
When you have
int main(void) {
    // SOME SETUP CODE
    while (1) {
        // SOME LOOPING CODE
you can change it to a normal Arduino sketch as:
    // SOME SETUP CODE
Note: If your 'main()' returns a value, remove the value since loop() returns 'void'.
