There have been various changes since the new core 3.0.x release. May I ask what library you are using now for frequency measurement? I haven't found anything that works. Thank you very much.
would help to know what frequency range and what is the source
Anemometer. There is a range of approximately 0 to 600Hz.
See if this project helps:
Ref:
Definitions:
GPIO_34 = Freq Meter Input
GPIO_33 = Oscillator output - to test Frequency Meter
To test freq Meter with internal oscillator, make connection between GIPO_34 and GPIO_33 (optional).
Change frequency, inputting value at Arduino console (1 Hz to 40 MHz)
if it is pulse timing you could simply attachInterrupts to check for rising and falling edges and use micros() to measure times, e.g.
// ESP32 - ESP32 measure pulse width and rising edge-to-edge time using micros()
#define RISE 18 // pin to input pulses
#define FALL 19
Serial.printf("\n\nESP32 measure pulse width and rising edge-to-edge time\n");
attachInterrupt(digitalPinToGPIONumber(RISE), rising, RISING); // detect rising edge on pin 16
attachInterrupt(digitalPinToGPIONumber(FALL), falling, FALLING); // detect falling edge on pin 17
volatile unsigned long pulseWidth = 0, pulseEdge = 0, pulseStart = 0, counter = 0;
void rising() {
pulseEdge = pulseEdge + (micros() - pulseStart);
pulseStart = micros();
void falling() {
// falling edge calculate pulse HIGH width
pulseWidth = pulseWidth + (micros() - pulseStart);
counter = counter + 1;
static unsigned long timer = millis();
if (millis() - timer >= 1000) {
timer = millis();
//Serial.println(counter);
unsigned long pw = (unsigned long)(pulseWidth / counter), pe = (unsigned long)(pulseEdge / counter);
Serial.printf("pulse HIGH width %luuSec %.3fmSec\n", (unsigned long)pw, pw / 1000.0);
Serial.printf("rising edge-to-edge time %luuSec %.3fmSec frequency %.3fHz\n", pe,
pe / 1000.0, 1.0e6 / pe);
pulseWidth = pulseEdge = counter = (volatile unsigned long)0;
some results
1KHz
pulse HIGH width 499uSec 0.499mSec
rising edge-to-edge time 998uSec 0.998mSec frequency 1002.004Hz
rising edge-to-edge time 999uSec 0.999mSec frequency 1001.001Hz
10KHz
pulse HIGH width 49uSec 0.049mSec
rising edge-to-edge time 99uSec 0.099mSec frequency 10101.010Hz
100Hz
pulse HIGH width 4999uSec 4.999mSec
rising edge-to-edge time 9999uSec 9.999mSec frequency 100.010Hz
1Hz
pulse HIGH width 500003uSec 500.003mSec
rising edge-to-edge time 1000008uSec 1000.008mSec frequency 1.000Hz
pulse HIGH width 500006uSec 500.006mSec
rising edge-to-edge time 1000011uSec 1000.011mSec frequency 1.000Hz
pulse HIGH width 500005uSec 500.005mSec
alternatively use esp_timer_get_time() from ESP Timer (High Resolution Timer)
