Hi everyone,
I'm trying to make simple frequency measurement with my arduino. Everytime digital pin 3 goes to LOW the magnet attached to the rotating shaft passed by the hall sensor.
The problem is that i have never coded in C++ and i'm probably making a lot of errors, but right now i'm stuck upon "expected unqualified-id before string constant". The error is given at the line " Void ISR()..."
unsigned long timer;
unsigned long prevtimer;
unsigned long deltat;
unsigned long frequency;
pinMode(3,INPUT);
timer=0;
prevtimer=0;
deltat=0;
frequency=0;
attachInterrupt(digitalPinToInterrupt(3),ISR,LOW);
if deltat!=0{
frequency=1/deltat;
Serial.println(frequency);
delay (500);
void ISR() {
timer=millis();
deltat=timer-prevtimer;
prevtimer=timer;
any ideas?
Thanks a lot and sorry if it's a really dumb question.
There were many problems with the code.
failure to use "volatile" with a globally defined variable used in an interrupt
incorrect if statement format
integer divide: 1/deltat will always be zero, if deltat is > 1
in my Arduino IDE, digitalPinToInterrupt() seems not to defined, so I substituted interrupt #1 for pin 3.
I try to avoid using keywords like ISR (they might be defined elsewhere)
I did not analyze the logic and I have some doubt that it will work -- not sure why you would want to use delay(500)
Try this (untested):
volatile unsigned long deltat;
float frequency;
pinMode(3,INPUT);
timer=0;
prevtimer=0;
deltat=0;
frequency=0;
attachInterrupt(1,cal_delta,LOW);
if (deltat!=0) frequency=1.0/deltat; //force floating point divide
delay (500);
void cal_delta() {
timer=millis();
prevtimer=timer;
Hi Jeremy,
Thanks a lot! I was arleady expecting a lot of troubles, since i've never coded in C++ and only coded in python before.
I'm going to try your code this evening, I just have a few questions about it.
You call deltat a volatile unsigned long, is that because it's used inside of the subfunction and in the main loop?
I got the digitalPinToInterrupt() straight from the page with an explanation about attachinterrupt(), i'm not really sure what it does exactly either :). But i don't understand your code a this point you change that to a 1, so you're looking for an interrupt at pin 1 but earlier you stated that pin 3 is your input pin?
the delay is to prevent my log window from being spammed like crazy.
Thanks
A common approach is to use the interrupt facility. This applies to tachometers, flow meters, and probably what you are doing. Google jaycar freetronics flow
Hi again,
I tested it and made a small adaptation to your code, i put the pin to interrupt to pin 2, that seems to be the only working pin for interrupts on my arduino. Right now he's calling cal_deltat but he won't go into the if loop in the main loop.
I can even print deltat in the main loop and it print's something greater then 0 but still he won't go into the if loop. Here's the current code
float frequency;
pinMode(2,INPUT);
timer=0;
prevtimer=0;
deltat=0;
frequency=0.0;
attachInterrupt(digitalPinToInterrupt(2),cal_deltat,RISING);
if (deltat>0.0) Serial.println(deltat);//frequency=1.0/deltat; //1.0 for float division
Serial.println(1.0/deltat);
delay (500);
void cal_deltat() {
timer=millis();
prevtimer=timer;
On the Arduino Uno or similar, digital pin 2 corresponds to interrupt #0. Digital pin 3 corresponds to interrupt #1. You have both possibilities, but your code has to be consistent.
Any variables shared between interrupts and other parts of the program must be declared volatile.
I don't know what this means. There is no "if loop" in the program.
I meant the if statement, if (deltat>0.0)...
But nevermind i reuploaded it and now it works fine
Thanks for all the help!
