samna
May 1, 2015, 1:43pm
1
Hello all,
Currently, I am working on a project where I need to measure the AC current in my circuit sensed by a current sensor (ACS712).
I want to calculate the average value of this current and also its frequency but I still do not know how?
I researched a function "pulseIn" which calculates the period of the square wave but I do not know how to integrate it into my program, knowing that my signal is sinusoidal.
Here is the code I realized:
int sensorValue = analogRead(A0);
Serial.println((510 - sensorValue) * 50.00/1023);
delay(250);
I am a beginner in programming, so I count on your help, thank you
What is this anonymous, magic number, supposed to represent?
Voltage has frequency. Current does not.
PaulS:
What? When I run AC voltage across a resistor does the current magically stay constant? Do you want to try that again?
Pardon!!!!
AC voltage across a resistor produces an AC current of the same frequency through the resistor.
Tom..
samna
May 1, 2015, 2:27pm
5
PaulS:
it represents two conversions:
valeur digital---->analog value.
Voltage value---> current value.
The following video explains very well these two conversions, I think you will understand with a video.
In the video, he uses a ACS712 5A, but I use a ACS712 20A that's why the values are not the same.
If you have more ambiguity, please ask me.
Are either of you two going to use a current sensor to measure frequency? Or are you going to measure the frequency of the voltage?
Current has magnitude!
PaulS:
AC Current has both magnitude AND frequency, exactly like voltage.
Regards,
Ray L.
samna
May 1, 2015, 3:18pm
8
I want to calculate the frequency of the current?
is it possible to calculate it using "pulsIn"? and if possible, how?
Pulse in would work best if you use a circuit to square up the input waveform.
PaulS:
Depends on what I had available. Either voltage or current would work fine.
