Hey,
I'm writing this here because I am completely new to arduino and this seems the fastest and best way to get good answers
I have some questions, I don't know if you can answer or not, I recently bought an arduino UNO and I want to know, if I can, how to generate output frequencies.
Imagine I need to light a led @ 40 hz and get some digital pin to fire up 400 times a second, how would I do it? Is it possible to do with an arduino?
Yes, I've seen that, although I don't know how accurate that will be, knowing is based on an if statement.
I've been reading this http://arduino.cc/en/Tutorial/SecretsOfArduinoPWM , is there anyone with more knowledge than I that can help me here?
this if statement takes time to compute, besides it is not accurate, if I have a huge list of things being done before or after the if , it will be always true
That is, the program can be programed to work at 40 hz when in fact is working at 30hz or less.
Just grab a scope and adjust the interval value to get 40Hz, pwm's cant go that low, only the 16bit timer can, and that is used to generate the milis if I'm not in mistake.
const int ledPin = 13; // the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
This should run at 1 Hz right?
Imagine I need to have a delay inside or
that needed to have something inside that code that needs 2 seconds for the arduino to complete?
This if will then be always true and the full loop would take 2 seconds plus (62.5nanoseconds * 6) right?
Almost 2 Hz no?
Why would you have a 'delay'?
That's what you're trying to avoid.
That's why it is called the blink without delay example.
If all you're doing is flashing a couple of LEDS at low frequecy, what could possibly take two seconds to complete?
