hello im kinda new to arduino but i dont understand wtf is going one can some one explain me (sorry for bad english)
unsigned long var = 0;
unsigned long var2 = 55;
if(fun() == true){
Serial.println("function return TRUE");
int fun(){
Serial.println(var); /// if i print this function will return me a TRUE
Serial.println(var2); /// but if i print this then function will return me a false
Ehm, in this sketch it looks like it's impossible to get 'fun' to 'true' also you can't use == true in this sketch in the if expression.. You use the true and false in boolean's.
If you had enabled the warnings, the compiler would have told you
C:\Users\noReturn.ino: In function 'int fun()':
C:\Users\noReturn.ino:18:1: warning: no return statement in function returning non-void [-Wreturn-type]
int fun() {
Serial.println(var); // no impact on result
Serial.println(var2); // no impact on result
return 0; // always false
Not true. While comparison to true or false is usually only done with booleans, they values can be stored in ints or bytes or chars.
OP: You lied when you said that fun() would return an int. You either must add a return statement or change the function return type to void.
