The following code works, but only if the code for "func()" is placed before setup() and loop(). If "func()" follows setup and loop, I get "func was not declared in this scope".
I'm using Arduino 1.8.2
I've tried to discover what rules might govern what the compiler do might in such cases, but so far have come up with a blank. Discussion encouraged!
int func(void) {
return 11;
int x = func();
Serial.print("x ");
Serial.println(x); //prints 11
Because the compiler is smart. It can see that the function is so small that it can be inlined. Then it sees that it is a constant expression known at compile time. So it just puts that constant in x. There is no function call by the time that the linker is looking for functions and function prototypes.
This is an edge case that the Arduino IDE doesn't handle properly with the magic function prototypes.
mjward:
The usual workaround as I understand it is to add the function prototype yourself to a .h file which you then #include in your .ino file.
It's not necessary to put it in a .h file if you don't want. This works fine:
int func(void);
int x = func();
Serial.print("x ");
int func(void) {
return 11;
