Dear forum members,
I need some help with the code I put together for controlling a variable capacitor’s movements. The capacitor is part of a magnetic loop antenna, of which you can adjust the resonant frequency by changing the capacitance. The capacitor is rotated by a stepper motor that is driven by an A4988 module, which itself is controlled by an Arduino Nano.
Basically, what it does is as you turn the capacitor clockwise/counterclockwise, fast or slow; an OLED screen shows the current position (between 0 and 2400). There are 4 buttons that are assigned to rotation (CW-slow, CCW-slow, CW-fast, CCW-fast) and a 5th that is a “function” button (for future development). There’s also a micro switch near the variable capacitor. These are all connected to the digital pins, which stay “HIGH” unless the buttons are depressed (pls. see the attached schematic).
The problem is that a function I put in the code doesn’t seem to work. It’s the “ZEROING” function that I call inside the “Void Setup”. Every time the circuit is powered on, the capacitor has to rotate until it hits and closes the microswitch, causing the D2 to go “LOW”. This normally stops the capacitor at its minimum capacitance value and also zeroes the step count so we get a reference point for adjusting the antenna the same way every time we use it.
I tried different things to understand why the “ZEROING” doesn’t work but couldn’t succeed. In my opinion, it’s not a mechanical problem because when I check the connection, I see that the D2 is always HIGH and goes LOW when I manually close the microswitch. The four buttons work as intended and turn the capacitor. The display correctly shows the step count.
I suspect that it’s a mistake a did when putting the code together. Speaking of the code, probably it’s very crude and can be improved but I’m limited by my narrow knowledge.
I would be glad if you can help me correct this issue. This is my first post, I hope I posted it in the correct sub-forum.
The code is below. My IDE is 1.8.7. The Nano is one with ATmega168.
#include <SPI.h>
#include <Wire.h>
// required for the OLED screen
#include "SSD1306Ascii.h"
#include "SSD1306AsciiAvrI2c.h"
// 0X3C+SA0 - 0x3C or 0x3D
#define I2C_ADDRESS 0x3C
// Define proper RST_PIN if required.
#define RST_PIN 4
SSD1306AsciiAvrI2c oled;
#define DISTANCE 1 // step-unit
int maxSteps = 2400; // max steps of the stepper motor, if a gearbox is used, steps x gearbox ratio.
int currentPosition = 0;
int sTEPP = 1; // real steps counter
int StepCounter = 0; // to make the stepper one step a time, used in conjunction with DISTANCE
int Stepping = false; // initial condition of this has to be false, don't touch
int speedDelay = 2000;// delay in sec or microsec, motor speed will slow down if too short (100 microsec etc) or too long (4000 milisec etc)
int MemPos01 = 1200; // Step number/position for min SWR at XXX frequency // for future development
int enaPin = 12; // A4988 enable pin - power to STEPPER if LOW
int microPin1 = 13; // A4988 microstepping MS1 pin for 1/2 stepping (HLL for 1/2, LHL for 1/4,
int microPin2 = 10; // A4988 microstepping MS3 pin (I needed only MS1 and MS3, anything besides 1/2 stepping lacks torque anyway)
int stepPin = 9; // A4988 step pin
int dirPin = 8; // A4988 dir pin
int butPinCCW = 7; // counterclockwise turn button (fast) // when looked from the stepper's end
int butPinCW = 6; // clockwise turn button (fast)
int butPinfineCCW = 5; // counterclockwise turn button (slow)
int butPinfineCW = 4; // clockwise turn button (slow)
int butPinFunc = 3; // Function button
int ZeroSwitch = 2; // Capacitor zeroing microswitch
int Measure = A0; // RF intensity measurement, analog input pin (not used, for semi-auto tuning version in the future)
#if RST_PIN >= 0
oled.begin(&Adafruit128x64, I2C_ADDRESS, RST_PIN);
#else // RST_PIN >= 0
oled.begin(&Adafruit128x64, I2C_ADDRESS);
#endif // RST_PIN >= 0
// Call oled.setI2cClock(400000);
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
// pinMode(11, OUTPUT); // this pin is reserved for future use
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
pinMode(7, INPUT);
pinMode(6, INPUT);
pinMode(5, INPUT);
pinMode(4, INPUT);
pinMode(3, INPUT);
pinMode(2, INPUT);
pinMode(A0, INPUT);
// Serial.begin (9600);
digitalWrite(stepPin, LOW);
digitalWrite(dirPin, LOW);
digitalWrite(microPin1, HIGH);
ZEROING ();
// This is to display the current position of the capacitor with respect to point 0 (max. capacitance)
void stepWRITE() {
oled.setFont(Verdana_digits_24);
oled.clear();
oled.set2X();
oled.print(currentPosition);
//delayMicroseconds (1000);
// This is to bring the capacitor to starting position (max. capacitance) on every start
// if too fast, it will close down the switch earlier
void ZEROING() {
if (digitalRead(ZeroSwitch) == HIGH && Stepping == false)
Stepping = true;
while (Stepping == true && digitalRead(ZeroSwitch) == HIGH)
digitalWrite(enaPin, LOW);
digitalWrite(dirPin, HIGH);
digitalWrite(stepPin, HIGH);
delayMicroseconds(speedDelay);
StepCounter = StepCounter + 1;
currentPosition = currentPosition + sTEPP;
// .println (currentPosition);
if (digitalRead(ZeroSwitch) == LOW) {
StepCounter = 0;
// Serial.println (currentPosition)
digitalWrite(enaPin, HIGH);
stepWRITE();
Stepping = false;
// Main loop, this is to turn the capacitor CW and CCW within the max-min points
if (digitalRead(butPinCW) == LOW && Stepping == false)
//digitalWrite(dirPin, LOW);
Stepping = true;
if (digitalRead(butPinCCW) == LOW && Stepping == false)
//digitalWrite(dirPin, HIGH);
Stepping = true;
if (digitalRead(butPinfineCW) == LOW && Stepping == false)
Stepping = true;
if (digitalRead(butPinfineCCW) == LOW && Stepping == false)
Stepping = true;
while (Stepping == true && digitalRead(butPinCW) == LOW)
if (currentPosition > 0)
// digitalWrite(2, HIGH); MS1
currentPosition = currentPosition - sTEPP;
// stepWRITE();
// digitalWrite (2, LOW); MS1
else {
// .println("Capacitor Maxi");
oled.clear();
oled.setFont(Callibri14);
oled.set2X();
oled.setCursor(0, 0);
oled.print("CAPACITOR");
oled.setCursor(0, 8);
oled.print("MINIMUM");
while (Stepping == true && digitalRead(butPinCCW) == LOW)
if (currentPosition < maxSteps)
// stepWRITE();
else {
// .println("Capacitor Mini");
oled.clear();
oled.set2X();
oled.setCursor(0, 16);
oled.print("MAXIMUM");
while (Stepping == true && digitalRead(butPinfineCW) == LOW)
// digitalWrite(3, HIGH);
delay(50);
delay(50);
stepWRITE();
// digitalWrite (3, LOW); MS3
else {
oled.clear();
oled.set2X();
oled.println("CAPACITOR"); // print idi bunlar sonradan ln ekledim !!!!!
oled.println("MINIMUM");
stepWRITE();
while (Stepping == true && digitalRead(butPinfineCCW) == LOW)
delay(50);
delay(50);
stepWRITE();
else {
oled.clear();
oled.set2X();
if (StepCounter == DISTANCE)
StepCounter = 0;
Stepping = false;
