Function not declared at this scope when #include <ESP8266WiFi.h>
I am creating an ESP8266 project to log the current status of my garage door (open or closed) to data.sparkfun.com. When I try to compile the code I get an error "'postDoorStatus' was not declared in this scope" (postDoorStatus refers to a function which actually posts the door status to the data.sparkfun.com site). If I re-order the functions so that the postDoorStatus function is BEFORE the loop function then no problems. If I comment out the #include <ESP8266WiFi.h> then no problem.
I have removed almost all the code to demonstrate - even this minimal code reproduces the problem.
//declare constants, global variables, and pin numbers
#define doorSensor 5     // GPIO 5 pin of ESP8266-12 will be the pin that sensor connects to
int lastDoorStatus = 0;  //global variable to track door status - initialize to 0 (open)
  pinMode (doorSensor, INPUT_PULLUP);
  int doorSensorValue = digitalRead(doorSensor);
  postDoorStatus(doorSensorValue);
void postDoorStatus(int doorSensorValue) {
  //do nothing here for troubleshooting purposes
full error message:
Arduino: 1.6.7 (Mac OS X), Board: "Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck"
/Users/XXXX/Dropbox/Arduino/Sketchbooks/not_in_scope_error_troubleshoot/not_in_scope_error_troubleshoot.ino: In function 'void loop()':
not_in_scope_error_troubleshoot:21: error: 'postDoorStatus' was not declared in this scope
exit status 1
enabled in File > Preferences.
In general, functions should be known to the compiler before you use them. For (to me) unknown reasons this however does not always seem to be the case (most Arduino code that I have seen / used does not seem to require it though).
You can add a prototype in the beginning of your code file
// prototypes here
void postDoorStatus(int doorSensorValue);
Alternatively you can create an include file in your project directory with all the prototypes of functions that you created and include that file in your source(s).
sterretje:
The IDE adds the prototypes automatically.
In this case an external tool (ctags) fails when a certain header is included.
The latest hourly build compiles this without errors.
sterretje:
The IDE automatically generates prototypes for you, sometimes doing it wrongly.
How to avoid the quirks of the IDE sketch file pre-preprocessing
With the IDE what's going on if we do declations functions before the setup ().
  1. IDE maintains all those declarations and does not make his.
  2. IDE overwrites all declarations and imposes his.
68tjs:
It does 1
Thanks.
Sorry it took me a while to get back to this project. Thanks for all the helpful comments although I'm not sure I can say I actually understand the problem better now. Seems to be an idiosyncracy.
AGS
