Hey everyone.
I'm trying to write a function with optional arguments.
for example (pseudo-code)
void myFunction(boolean option){
if option is not defined
do some default action
if option is defined
if option
action for option==true
action for option==false
i know that the Serial.print function will take optional arguments for printing various output formats.
I hope i'm not asking a blatantly obvious question, and I have tried to search the forum and 'interwebs' for a solution... no luck!
-so could someone please point me in the right direction for how to define an optional argument for a function call?
Thanks in advance for yor time
I'm not sure if it works on the Arduino, but the usual way, in C/C++, is like this:
Function prototype:
functionReturnType FunctionName(optionalArgType optArg = defaultValue);
Implementation:
functionReturnType FunctionName(optionalArgType optArg)
// optArg will have default value, unless one is supplied
Calls:
FunctionName(); // Use the default value
FunctionName(42); // Use specific value
I think you need to overload the function. I suppose like this from the print.cpp file
void Print::print(const char str[])
write(str);
void Print::print(char c, int base)
print((long) c, base);
void Print::print(unsigned char b, int base)
print((unsigned long) b, base);
Thanks PaulS. that worked.
pracas>> i'm not sure how it works, defining multiple functions by the same name, but with different arguments. :-?
Anyway. thanks for your replies. I think i'll be able to do what I intended
That is called overloading.
