I did add some lines of code in the last 3 hours so here is a version without a lot of functions, that produces the same error (After I added RTC-Support).
FYI: The Annikken Andee is a Bluetooth Shield which lets me communicate with my iPhone and the Arduino. This also might be the source of the errors. The Arduino-Restart occurs, when I press a certain button on my iPhone. But maybe someone finds something regardless.
I switched to the Arduino Mega and I tried to optimise the variables, so memory shouldn't be a problem.
#include <Andee.h>
#include <SPI.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#include "ds3231.h" //Library for the DS3231 RTC-Chip
uint8_t time[8];
char recv[128];
unsigned int recv_size = 0;
const unsigned int MAIN = 0;
const unsigned int COL_CHANGE = 1;
const byte PIN_G = 3;
const byte PIN_R = 5;
const byte PIN_B = 6;
byte r = 0;
byte g = 0;
byte b = 0;
AndeeHelper displayTime;
AndeeHelper displayAlarm;
AndeeHelper alarmInputButton;
AndeeHelper changeColorButton;
AndeeHelper redSlider;
AndeeHelper greenSlider;
AndeeHelper blueSlider;
bool mainState = true;
boolean sleeping = true;
bool alarm = false;
char timeString[30];
char alarmString[30];
int timeHour;
int timeMinute;
int timeSecond;
int alarmHour = 8;
int alarmMinute = 0;
int alarmSecond = 0;
bool timeNotSet = true;
LiquidCrystal lcd(9, 10, 2, 4, 7, 8);
byte clock[8] = {
B00000,
B00000,
B01110,
B10101,
B10111,
B10001,
B01110,
B00000
void setup(){
Wire.begin();
DS3231_init(DS3231_INTCN);
memset(recv, 0, 128);
lcd.begin(16, 2);
lcd.createChar(0, clock);
Andee.begin();
displayTime.setId(0);
displayTime.setType(DATA_OUT);
displayTime.setLocation(0,0,FULL);
displayTime.setTitle("Time");
displayTime.setColor(THEME_MIDNIGHT_DARK);
displayAlarm.setId(1);
displayAlarm.setType(DATA_OUT);
displayAlarm.setLocation(1,0,FULL);
displayAlarm.setTitle("Alarm");
displayAlarm.setColor(THEME_MIDNIGHT_DARK);
alarmInputButton.setId(2);
alarmInputButton.setType(TIME_IN); // Sets object as a time input button
alarmInputButton.setLocation(2,0,FULL);
alarmInputButton.setTitle("Set Alarm");
alarmInputButton.setColor(THEME_MIDNIGHT_DARK);
changeColorButton.setId(3);
changeColorButton.setType(BUTTON_IN); // Sets object as a time input button
changeColorButton.setLocation(3,0,FULL);
changeColorButton.setTitle("Change LED-WakeUp-Color");
changeColorButton.requireAck(true);
changeColorButton.setColor(THEME_MIDNIGHT_DARK);
// Draw red slider
redSlider.setId(4);
redSlider.setType(SLIDER_IN); // Set object as a slider
redSlider.setLocation(0, 0, FULL); // Sliders can only be full size
redSlider.setTitle("Red Channel");
redSlider.setSliderMinMax(0, 255);
redSlider.setSliderInitialValue(0);
redSlider.setSliderNumIntervals(256); // Set as discrete slider
redSlider.setSliderReportMode(ON_VALUE_CHANGE); // Update values as you're moving
redSlider.setSliderColor(THEME_RED); // Slider bar colour
redSlider.setColor(THEME_RED_DARK); // Slider background colour
// Draw green slider
greenSlider.setId(5);
greenSlider.setType(SLIDER_IN); // Set object as a slider
greenSlider.setLocation(1, 0, FULL); // Sliders can only be full size
greenSlider.setTitle("Green Channel");
greenSlider.setSliderMinMax(0, 255);
greenSlider.setSliderInitialValue(0);
greenSlider.setSliderNumIntervals(256); // Set as discrete slider
greenSlider.setSliderReportMode(ON_VALUE_CHANGE); // Update values as you're moving
greenSlider.setSliderColor(THEME_GREEN); // Slider bar colour
greenSlider.setColor(THEME_GREEN_DARK); // Slider background colour
// Draw blue slider
blueSlider.setId(6);
blueSlider.setType(SLIDER_IN); // Set object as a slider
blueSlider.setLocation(2, 0, FULL); // Sliders can only be full size
blueSlider.setTitle("Blue Channel");
blueSlider.setSliderMinMax(0, 255);
blueSlider.setSliderInitialValue(0);
blueSlider.setSliderNumIntervals(256); // Set as discrete slider
blueSlider.setSliderReportMode(ON_VALUE_CHANGE); // Update values as you're moving
blueSlider.setSliderColor(THEME_BLUE); // Slider bar colour
blueSlider.setColor(THEME_BLUE_DARK); // Slider background colour
void loop(){
//////////CLOCK///////////
char in;
unsigned long now = millis();
struct ts t;
DS3231_get(&t);
sprintf(timeString, "%02d:%02d:%02d", t.hour, t.min, t.sec);
//Update State
if(mainState == true)
//UpdateMain
displayTime.update();
displayAlarm.update();
alarmInputButton.update();
changeColorButton.update();
//Show LED Color
analogWrite(PIN_G, 0);
analogWrite(PIN_R, 0);
analogWrite(PIN_B, 0);
if(mainState == false)
redSlider.update();
greenSlider.update();
blueSlider.update();
changeColorButton.setTitle("BACK");
//Show LED Color
analogWrite(PIN_G, redSlider.getSliderValue(INT));
analogWrite(PIN_R, greenSlider.getSliderValue(INT));
analogWrite(PIN_B, blueSlider.getSliderValue(INT));
if( alarmInputButton.isPressed() )
alarmInputButton.setDefaultTime(timeHour, timeMinute, 0); // Format: hour, minute, second
alarmInputButton.ack();
alarmInputButton.getTimeInput(&alarmHour, &alarmMinute, &alarmSecond);
if((t.hour == 0 && t.min == 0 && t.sec == 00 || timeNotSet) && Andee.isConnected()){
Andee.getDeviceTime(&timeHour, &timeMinute,&timeSecond);
sprintf(timeString, "T%02d%02d%02d%01d%01d%d",t.sec, t.min, t.hour, t.wday, t.mday, t.mon, t.year);
struct ts t;
t.sec = timeSecond;
t.min = timeMinute;
t.hour = timeHour;
t.wday = 1;
t.mday = 01;
t.mon = 01;
t.year = 2014;
DS3231_set(t);
timeNotSet = false;
displayTime.setData(timeString);
sprintf(alarmString, "%02d:%02d", alarmHour, alarmMinute);
displayAlarm.setData(alarmString);
if( changeColorButton.isPressed() )
changeColorButton.ack();
mainState = false;
Andee.clear();
mainState = true;
Andee.clear();
//Check Alarm
if(timeHour == alarmHour && timeMinute == alarmMinute && alarm == true)
sleeping = false;
//checkWakeUp();
if(sleeping == false)
for (int brightness=0; brightness<240; brightness++){
r += (float)redSlider.getSliderValue(FLOAT) / 240.00;
g += (float)greenSlider.getSliderValue(FLOAT) / 240.00;
b += (float)blueSlider.getSliderValue(FLOAT) / 240.00;
analogWrite(PIN_R,r);
analogWrite(PIN_G,g);
analogWrite(PIN_B,b);
delay(250);
sleeping = true;
r = 0;
g = 0;
b = 0;
lcd.setCursor(4, 0);
lcd.print(timeString);
lcd.setCursor(4, 1);
lcd.print(alarmString);
if(analogRead(5) > 1000)
lcd.setCursor(9, 1);
lcd.print(" ");
lcd.write((uint8_t)0);
else{
lcd.print(" ");
AndeeLightAlarmRelease.ino (6.78 KB)
