I was trying to generate a frequency with the resolution of 0.1Hz/steps from 0 to 1kHz.
The code is below:
pinMode(13,OUTPUT);
digitalWrite(13,HIGH);
delay(5000);
digitalWrite(13,LOW);
delay(5000);
by delaying 5 seconds after triggering HIGH and LOW , it is shown in the oscilloscope the frequency is
0.1Hz (100mHz) for delay = 5000 after HIGH and LOW;
0.2Hz (200mHz) for delay = 2500 after HIGH and LOW;
up until
0.9Hz (901mHz) for delay = 555 after HIGH and LOW;
when I tried to generate 10.1 Hz, which by 1/10.1Hz and divide by 2 to have the delay at high and delay at low, which is 49 ms after high and 49ms after low. The result is I get 10.16 Hz which is fine.
But when I tried to generate frequency of 49.3Hz , I have changed from delay to delayMicroseconds and here's my new code:
pinMode(13,OUTPUT);
delayMicroseconds(10142);
The frequency read by oscilloscope is : 49.01 Hz
And if I try for frequency of 587.3 Hz, the delay is 851 microseconds.
pinMode(13,OUTPUT);
delayMicroseconds(851);
The frequency read by oscilloscope is : 582.1 Hz which is a bit diverted from my required value of 587.3 Hz.
Lets say, if I tries with frequency of 800.1 Hz the delay is 624 ms. The code is:
pinMode(13,OUTPUT);
delayMicroseconds(625);
The frequency read by oscilloscope is : 793.7 Hz . What I want is 800.1 Hz.
Is there any other method to generate frequency of 0.1Hz of resolution with a better accuracy?
