Try commenting out the printing, reducing the delays, and then measure the results.
I have this code. i am getting Data like that
#define LED 16 // Led in NodeMCU at pin GPIO16 (D0).
pinMode(LED, OUTPUT); // LED pin as output.
digitalWrite(LED, HIGH);// turn the LED off.(Note that LOW is the voltage level but actually
//the LED is on; this is because it is acive low on the ESP8266.
delayMicroseconds(3); // wait for 1 second.
// Serial.println("High");
digitalWrite(LED, LOW); // turn the LED on.
// Serial.println("LOW");
If it is too long, shorten the delays. It takes time to digitalWrite, delay, and to loop, so you may not need the full delayMicroseconds(3);
My requirement is to generate 3us On time and 3us off time.
what can i do?
I have Arduino Uno and NodeMCU unit. Best way to get above requirement code and sample code
This is one way of speeding up the pin toggling on the ESP8266/nodemcu by direct port manipulation: Direct GPIO port register manipulation - Everything ESP8266
