I am making a device that the main function is to output a PWM signal that is variable in range of 20-120Hz and duty cycle variable between 0-100%. I have a lot of other things going on in the program and cannot put it in my main loop function because it will be interrupted by other events. So my idea is to have the flashing in a timer interrupt. I can get it working when I just toggle the output, but when I try to incorporate the duty cycle it gets weird and out of sync. Does anyone have any ideas on how I could fix this?
Here is what I am doing right now, but I very well may be doing this completely wrong.
That’s a good idea. I didn’t want to do that originally because it only allows for PWM on pins 9 and 10, and I already had my circuit made. This way seems much better than what I was doing, so I will modify my circuit to make this work.
karlschmaltz:
I see you already chose a solution, but keep this idea for reference:
The "PWM_OUT", DDR and BIT are defined by you depending on what pin you want to use. Then, setup any timer you wish to any frequency you wish (times 256) and then simply put a value from 0 to 255 into "value".
Since "count" is 8 bit, it just spins around FF, FE, FD,....2, 1, 0, FF... etc... and the pin is turned on or off depending on the comparison of "count" to "value".
Since one PWM cycle is 256 interrupts long, you need to take your desired PWM rate and multiply by 256. For example, if you want a 100 Hz. PWM frequency, you set the timer rate to 25600 and then the output changes 100 times per second with a duty cycle depending on "value".
