Blockzitat
I have written two programs, one for Arduino and one for processing. Both programms work together to build a generic control panel for process (control of automation, for example control any type of actuator, relay, lamps, cameras, alarms, motor, servos, light signals, railway trakc, model railway, etc.The idea is to submit both programms to put in category tutorials for new people, therefore I am submiting them for improvements , comments in general, etc.
Follows the Arduino programm
[code]
// Control Panel Ard_to_pross 25 06-23
/* If the programm receives a number "1" (room1) switch ON Led 1 and return to process the character "B",
* receives "2" (room 2) switch ON Led 2 On and return to process the character "C"
* receives "3" (room 3) switch ON Led 3 On and return to process the character "D"
* receives "4" (room 4) switch ON Led 4 On and return to process the character "E"
* receives "5" (room 5) switch ON Led 5 On and return to process the character "F"
* receives "6" (room 6) switch ON Led 6 On and return to process the character "G"
* To establish the handshake with the PC an "A" will be sent until contact is established.
int val; // Data received from serial port
char controlNunber;
int led1State = HIGH; // current State of LED 1 at start
int led2State = HIGH; // current State of LED 2 at start
int led3State = HIGH; // current State of LED 3 at start
int led4State = HIGH; // current State of LED 4 at start
int led5State = HIGH; // current State of LED 5 at start
int led6State = HIGH; // current State of LED 6 at start
int ledPin1 = 12; // Set the pin to digital I/O 12
int ledPin2 = 11; // Set the pin to digital I/O 11
int ledPin3 = 10; // Set the pin to digital I/O 10
int ledPin4 = 9; // Set the pin to digital I/O 9
int ledPin5 = 8; // Set the pin to digital I/O 8
int ledPin6 = 7; // Set the pin to digital I/O 7
pinMode(ledPin1, OUTPUT); // Declare pin 12 as an output
pinMode(ledPin2, OUTPUT); // Declare pin 11 as an output
pinMode(ledPin3, OUTPUT); // Declare pin 10 as an output
pinMode(ledPin4, OUTPUT); // Declare pin 9 as an output
pinMode(ledPin5, OUTPUT); // Declare pin 8 as an output
pinMode(ledPin6, OUTPUT); // Declare pin 7 as an output
Serial.begin(9600); // Serial Port speed
establishContact(); // send a character "A" to establish contact until receiver responds
if (Serial.available() > 0) // if serial available functions returns 1
// it means that some data has been received in the
// serial buffer of Arduino
val = Serial.read();
// val = Serial.read();
// To check the value of variavle val uses either the ASCII code for the character or alternative
//the character between "" example write '1' or number 49 ASCII code for 1.
if (val == 49) // Check if an '1' has been received 49 is ASCI code for "1"
digitalWrite (ledPin1, led1State); // Turn ON Led Room 1
Serial.println("B"); // Return B, Led switched on
led1State =! led1State;
delay (50);
if (val == 50) //Check if an '2' has been received 50 is ASCI code for "2"
digitalWrite (ledPin2, led2State); // Turn OFF Led Room 2
Serial.println("C"); // Return C,Led switched on
led2State =! led2State;
delay(50);
if (val == '3') //Check if an '3' has been received.
digitalWrite (ledPin3, led3State); // Turn On Led Room 3
Serial.println("D"); // Return C,Led switched on
led3State =! led3State;
delay(50);
if (val == '4') //Check if an '4' has been received
digitalWrite (ledPin4, led4State); // Turn On Led Room 4
Serial.println("E"); // Return E,Led switched on
led4State =! led4State;
delay(50);
if (val == '5') //Check if an '5' has been received
digitalWrite (ledPin5, led5State); // Turn On Led Room 5
Serial.println("F"); // Return F,Led switched on
led5State =! led5State;
delay(50);
if (val == '6') //Check if an '6' has been received
digitalWrite (ledPin6, led6State); // Turn On Led Room 6
Serial.println("G"); // Return G,Led switched on
led6State =! led6State;
delay(50);
// Routine to send a character "A" to establish contact until receiver responds
void establishContact()
while (Serial.available() <= 0)
Serial.println("A"); // send a capital A to process
delay(300);
void ready ()
Serial.println("R"); // send a capital R to process
delay(300);
[/code]
Here follows the Processing programm
// Control Panel pross to Ard 25 06 23
// Generic Control Panel
// Works with programm: Control Panel Ard_to_pross 25 06-23
/* Example for Control Switching of LED (LED-Control)
LEDs can be change for any type of actuator, relay, lamps, cameras, alarms, motor, servos, light signals, etc.
This programm can be changed to display for example a process, a railway track, etc, and linked with Arduino
can control physical elements.
The programm contains the communication overhead for serial communication with processing programms
Programm draw six buttons
Click on one button will send to arduino a number 1, 2, 3, 4, 5 or 6 according to the room number
Arduino will switch the corresponding Led and answer with the character "B" (room1), "C" (room 2), "D" (room 3),
"D" (room4), "E" (room 5), "F" (room6) and processing will change the color of the button and write "On".
A new click on a button will change again the status of the button(change colour and write Off)
Arduino will change the status of the Led (Toggle)
import processing.serial.*; //import the Serial library
Serial myPort; //the Serial port object
int portIndex = 0; // set this to the port connected to Arduino
int val; // Data received from the serial port
int tog1 = 0; // Toggle switch for On/Off room1
int tog2 = 0; // Toggle switch for On/Off room2
int tog3 = 0; // Toggle switch for On/Off room3
int tog4 = 0; // Toggle switch for On/Off room4
int tog5 = 0; // Toggle switch for On/Off room5
int tog6 = 0; // Toggle switch for On/Off room6
char controlNunber;
Boolean firstContact = false; // Since we are doing serial handshaking
// we need to check if we have heard from the microcontroller
size(300, 300); //make our canvas 200 x 200 pixels big
// initialize the serial port and set the baud rate to 9600
myPort = new Serial(this, Serial.list() [0], 9600);
myPort.bufferUntil ('\n');
background(200); //set it here so no fuzzy text on screen
//Initial text on canvas mask, all buttons yellow with Off written on them.
// Drawing of buttons
//Initial text on canvas mask, all lights OFF start
fill(255,252,214); // Room 1
rect(50, 30, 50,50); // (Origin (x,y) width, height
fill(15,13,13);
text("Room 1", 55,25);
text("Off", 66,60);
fill(255,252,214); // Room 2
rect(200, 30, 50, 50);
fill(15,13,13);
text("Room 2", 205,25);
text("Off", 213,60);
fill(255,252,214); // Room 3
rect(50, 120, 50,50);
fill(15,13,13);
text("Room 3 ", 55,115);
text("Off", 68,150);
fill(255,252,214); // Room 4
rect(200, 120, 50, 50);
fill(15,13,13);
text("Room 4", 205,115);
text("Off", 213,150);
fill(255,252,214); // Room 5
rect(50, 210, 50,50);
fill(15,13,13);
text("Room 5 ", 55,205);
text("Off", 68,240);
fill(255,252,214); // Room 6
rect(200, 210, 50, 50);
fill(15,13,13);
text("Room 6", 205,205);
text("Off", 216,240);
//Initial text on canvas mask, all lights OFF End
// Control Panel Ready Light Start
// Arduino has all Leds Off. Start, ready button is red until ready to operate when it change to green.
fill(250,46,28);
circle(150, 150, 20);
fill(15,13,13);
text("Ready", 135,135);
// Control Panel Ready Light End
void draw()
if (mousePressed == true) // Check where is the mouse set start
if(mouseX >= 50 && mouseX < 100 && mouseY >= 50 && mouseY < 100)
//println(" Mouse pressed on Button room 1");
myPort.write('1'); //send a 1
myPort.write ('0');
delay (150);
if(mouseX >= 200 && mouseX < 250 && mouseY >= 50 && mouseY < 100)
//println(" Mouse pressed on Button room 2");
myPort.write('2'); //send a 2
myPort.write ('0');
delay (150);
if(mouseX >= 50&& mouseX < 100&& mouseY >= 120 && mouseY < 170)
//println(" Mouse pressed on Button room 3");
myPort.write('3'); //send a 3
myPort.write ('0');
delay (150);
if(mouseX >= 200 && mouseX < 250 && mouseY >= 120 && mouseY < 170)
//println(" Mouse pressed on Button room 4");
myPort.write('4'); //send a 4
myPort.write ('0');
delay (150);
if(mouseX >= 50&& mouseX < 100&& mouseY >= 210 && mouseY < 260)
//println(" Mouse pressed on Button room 5");
myPort.write('5'); //send a 5
myPort.write ('0');
delay (150);
if(mouseX >= 200 && mouseX < 250 && mouseY >= 210 && mouseY < 260)
// println(" Mouse pressed on Button room 6");
myPort.write('6'); //send a 6
myPort.write ('0');
delay (150);
// Check where is the mouse set end
// Check If data is available,
if ( myPort.available() > 0)
val = myPort.read(); // read it and store it in val
// print(val); //for debbuging
fill(28,250,92); // If data is in buffer, chage Ready Button to green. Operation can start
if ((val) == 66) // "B" received, Led switched on
controlNunber = 66; // ASCII code for "B", Alternative instead of ASCII code it can be used: "B"
cleanPanel(controlNunber);
imprimir(controlNunber);
if ((val) == 67) // "C" received, Led switched Off
controlNunber = 67; // ASCII code for "C"
if ((val) == 68) // "C" received, Led switched Off
controlNunber = 68; // ASCII code for "D"
if ((val) == 69) // "E" received, Led switched Off
controlNunber = 69; // ASCII code for "E"
if ((val) == 70) // "F" received, Led switched Off
controlNunber = 70; // ASCII code for "F"
if ((val) == 71) // "F" received, Led switched Off
controlNunber = 71; // ASCII code for "G"
void cleanPanel(char x) //To clear text redraw the button and write it again start
//println("x", x); for debbuging
switch(controlNunber)
case 'B': // Room 1
if ((val == 66) && (tog1 == 1))
fill(255,252,214);
fill(106,242,10);
case 'C': // Room 2
if ((val == 67) && (tog2 == 1))
fill(255,252,214);
rect(200, 30, 50,50);
fill(106,242,10);
case 'D': // Room 3
if ((val == 68) && (tog3 == 1))
fill(255,252,214);
fill(106,242,10);
case 'E': // Room 4
if ((val == 69) && (tog4 == 1))
fill(255,252,214);
rect(200, 120, 50,50);
fill(106,242,10);
case 'F': // Room 5
if ((val == 70) && (tog5 == 1))
fill(255,252,214);
fill(106,242,10);
case 'G': // Room 6
if ((val == 71) && (tog6 == 1))
fill(255,252,214);
rect(200, 210, 50,50);
fill(106,242,10);
// println(" clear ON", tog6,val); for debbuging
default:
//println("Zulu"); // Does not execute
//To clear text redraw the button and write it again end
void imprimir(char y) // Imprimir legende on Button (On or Off) Start
// println("x", y); for debbuging
case 'B': // Room 1
fill(15,13,13);
if (tog1 == 0)
tog1= 1;
text("On", 66,60);
tog1= 0;
text("Off", 66,60);
case 'C':
fill(15,13,13); // Room 2
if (tog2 == 0)
tog2= 1;
text("On", 213,60);
tog2= 0;
case 'D': // Room 3
fill(15,13,13);
if (tog3 == 0)
tog3= 1;
text("On", 66,150);
tog3= 0;
text("Off", 66,150);
case 'E': // Room 4
fill(15,13,13);
if (tog4 == 0)
tog4= 1;
text("On", 213,150);
tog4= 0;
case 'F': // Room 5
fill(15,13,13);
if (tog5 == 0)
tog5= 1;
text("On", 66,240);
tog5= 0;
text("Off", 66,240);
break ;
case 'G': // Room 6
fill(15,13,13);
if (tog6 == 0)
tog6= 1;
text("On", 213,240);
tog6= 0;
text("Off", 213,240);
// Imprimir legende on Button (On or Off) end
default:
{ //println("Zulu"); // Does not execute
