get a integer from char* ...?
Hi all,
I'm trying to modify the UdpServer example from the UIPEthernet library so that I can send my arduino short messages over UDP, like "SR125", then split that message into "SR1" (meaning servo 1) and then the value "25". I get the "SR1" message filtered out just fine, it converts to string, but getting the number part from the char* seems more tricky..
If anyone could give me a push in the right direction I would be very happy! :slight_smile:
  // initialization of the variables
  char command[3];      // commandstring
  String value = "";        // string with the value
  unsigned int vnumber; // the value as integer
  boolean flag = true;  // a flag to seperate the command from the value
  //check for new udp-packet:
  int size = udp.parsePacket();
  if (size > 0) {
    int i=0;
    do
        char* msg = (char*)malloc(size+1);
        int len = udp.read(msg,size+1);
        msg[len]=0;
        Serial.print("received: '");
        Serial.print(msg);
          command[0]=msg[0];
          command[1]=msg[1];
          command[2]=msg[2];
          value= String(msg[3])+String(msg[4])+String(msg[5]);
        free(msg);
    while ((size = udp.available())>0);
    //finish reading this packet:
    udp.flush();
    Serial.println("'");
    command[3] = '\0';
    value += "\0";      // necessary - the string ends here
    vnumber = value.toInt();  // string to integer, but it doesn't seem to do the trick
    Serial.println(command);
    Serial.println(value); // this now prints a blank space
    Serial.println(vnumber); // this now prints 0 no matter what number it gets
    // this part converts the command to hardware
    if (String(command) == "SR1")
      Servo1.write(vnumber);
    if (String(command) == "SR2")
      Servo2.write(vnumber);
Using atoi() is tricky?
Not a good idea. You know the maximum (reasonable) size of a packet. Allocate a fixed size array.
There is no excuse for converting each letter to a String. There is no excuse for using String at all.
gorgon:
...like "SR125", then split that message into "SR1" (meaning servo 1) and then the value "25". I get the "SR1" message filtered out just fine, it converts to string, but getting the number part from the char* seems more tricky..
As Paul says, atoi() is your friend.
You might want to think about splitting your message on the 'SR' then convert the '1' into an integer, which you might use as an index into an array of servos.
Also. Read your code again. You enter the IF conditional when size is > 0 but then proceed to always reading a message of more than one byte. Is that what you mean to do?
PaulS:
trickiness is relative i guess, so tricky for me being unexperienced :slight_smile:
So, atoi will convert anything to integer, that's great. Then I would need first to convert the char array from say: 2, 5, 6 into 256, and not into 2+5+6 as integers and end up with 13. I guess that's where impulse to convert it to a String came from, I'm coming from Smalltalk (/Supercollider). How would I go about this in arduino?
PaulS:
Thanks, I know I can make this.
And thanks for the advice!
...2+5+6 as integers...
That works, but you'd need to change it a bit: 2 * 100 + 5 * 10 + 6 * 1 = 256.
MattS-UK:
That's a good idea, thanks!
MattS-UK:
This is in the UdpServer example from the UIPEthernet lib. I thought this meant that it won't perform udp.read unless there's anything to read...
econjack:
Haha, great, offcourse! Logic can sometimes be... very logical! XD
Ah, but now when I do this:
value= (atoi(msg[3])*100)+(atoi(msg[4])*10)+(atoi(msg[5])*1);
I get the error:
invalid conversion from 'char' to 'const char*'
Naw...my comment was meant to be tongue-in-cheek. atoi() expects a null-terminated sequence of characters. So if you want to convert it to a number with an input string of "SR125" and expect to get 25 back, you would need to use:
val = atoi(&msg[3]);
which assumes msg is a null-terminated character array. As to my comment, you could use:
val = ((mess[3] - '0') * 10) + ((mess[4] - '0');
and get the right value, but that seems to be the hard way to do it.
Ok, so now I'm here:
value = ((msg[3] - '0') * 100) + ((msg[4] - '0')*10) + ((msg[5] - '0')*1);
(and value is now an unsigned int)
If i send values over 100 it's fine, but it gets problematic with lower values like 25 because then the 2 is multiplied by 100 and the 5 is multiplied by 10, and the last msg[5] gets the value of -48 which I don't know the reason for.
Is there a method to do this?
My values will keep within the range of 0-255.
Every time you press a key on your keyboard, a key code gets sent from the keyboard to the computer. These are called ASCII codes. The keycode for a zero is 48, for 1 it's 49, 2 is 50, and so on. So, assuming msg[3] is the character '2', the expression:
msg[2] - '0'
resolves to:
msg[2] - '0'
'2' - '0'
50 - 48
2
Therefore, subtracting the ASCII key code for zero from any numeric digit character gives you that character as a numeric.
Finally, give up on the conversions on msg[]. Instead, if you can't assuming the incoming message is a null-terminated character array, try this:
char msg[7];
int len;
memset(msg, '\0', 7);   // Set all elements to null
len = udp.read(msg,7);
// msg[len] = '\0';           // You could do away with memset() statement if the
                              // read() call does return the message length.
value = atoi(&msg[3]);
You said that the number can never be more than 255, so at most, you need 7 characters: "SR1255", or 6 plus one for the null termination character. The memset() call sets all elements to null, so you know whatever comes in has a null at the end of the array. Get rid of malloc() and free(), they just aren't a real good idea if they can be avoided.
Hi econjack,
Thanks for this, it reduces the udp.read process to something more understandable for me.
It does not however answer my question; I still have to convert the last 3 (or 4 with the null) characters of the msg into an integer..
I think it does answer your questions. If you need to know which servo, and it is always the 3rd character, then:
int servoNumber;
int value;
int len;
char msg[7];
servoNumber = msg[2] - '0';   // Servo number
msg[6] = '\0';
value = atoi(&msg[3]);        // Value from the read
It does indeed! Thank you for your help :slight_smile: I'll post the code here after it's cleaned up a bit.
Actually, you should use the length returned from the call (len) to set the null. Change the null assignment to:
msg[len] = '\0';
gorgon:
What would happen were a properly formed UDP packet containing just 1 byte, arrive at your network interface?
Buffer checking is a hot topic at the moment. A similar bug caused the Heartbleed exploit, which has been all over the news recently.
I ended up using a different library, but now it works smoothly. The finished code is here:
http://forum.arduino.cc/index.php?topic=178024.msg1702783#msg1702783
Thanks for your help all of you!
