Suppose I have a variable of string object type. The length of the string is Y. I would like to retrieve the last X characters from this string. How can this be done?
EDIT: I just had an idea! Get the length first and subtract from there! Any better alternatives?
The usual solution is "don't use the String object type". Particularly not if you are doing things like this. the substring string method creates a new object on the heap, which has got to be cleaned up etc etc.
PaulMurrayCbr:
Why is String object bad? Does the new object on the heap needs to be manually cleaned up by code?
Below are the String functions which have some good examples. You could use your approach to get the length of the String, subtract the number of characters of interest on the end of the String, then use the substring() function to capture the characters of interest.
The String class has a lot of useful stuff in it, but its two biggest drawbacks are: 1) it eats up more memory than an equivalent program using c strings, and 2) it can fragment memory. In the code below, the String class version uses 3512 bytes while the c string version uses 1870 bytes. When you're working with a few nano-acres of memory, the cost of using Strings is pretty steep.
int len;
// String testStr = "This is a test"; // This version takes 3512 bytes
// len = testStr.length();
// Serial.println(testStr.substring(len - 3, len));
char testStr[] = "This is a test"; // This version takes 1870 bytes
len = strlen(testStr);
Serial.println(&testStr[len - 3]);
