Get Microphone Sample On-demand from Portenta H7 Vision Shield
I am using the Portenta H7 and the vision shield with the built-in MP34DT06JTR microphone.
I am trying to adapt the PDMSerialPlotter to my application but I'm not liking the fact that it is fetching the audio samples in chunks. I would like to use this microphone with a buffer size of 1 and no ISR. I want to just be able to call a method to get current instantaneous reading. The Portenta H7 starts to behave strangely (flashing red led) when I try to reduce the buffer size to 128 or lower:
  This example reads audio data from the on-board PDM microphones, and prints
  out the samples to the Serial console. The Serial Plotter built into the
  Arduino IDE can be used to plot the audio data (Tools -> Serial Plotter)
  Circuit:
  - Arduino Nano 33 BLE board, or
  - Arduino Nano RP2040 Connect, or
  - Arduino Portenta H7 board plus Portenta Vision Shield
  This example code is in the public domain.
#include <PDM.h>
// default number of output channels
static const char channels = 1;
// default PCM output frequency
static const int frequency = 16000;
// Buffer to read samples into, each sample is 16-bits
short sampleBuffer[128];
// Number of audio samples read
volatile int samplesRead;
  while (!Serial);
  // Configure the data receive callback
  PDM.onReceive(onPDMdata);
  // Optionally set the gain
  // Defaults to 20 on the BLE Sense and 24 on the Portenta Vision Shield
  // PDM.setGain(30);
  // Initialize PDM with:
  // - one channel (mono mode)
  // - a 16 kHz sample rate for the Arduino Nano 33 BLE Sense
  // - a 32 kHz or 64 kHz sample rate for the Arduino Portenta Vision Shield
  if (!PDM.begin(channels, frequency)) {
    Serial.println("Failed to start PDM!");
    while (1);
  // Wait for samples to be read
  if (samplesRead) {
    // Print samples to the serial monitor or plotter
    for (int i = 0; i < samplesRead; i++) {
      if(channels == 2) {
        Serial.print("L:");
        Serial.print(sampleBuffer[i]);
        Serial.print(" R:");
        i++;
      Serial.println(sampleBuffer[i]);
    // Clear the read count
    samplesRead = 0;
 * Callback function to process the data from the PDM microphone.
 * NOTE: This callback is executed as part of an ISR.
 * Therefore using `Serial` to print messages inside this function isn't supported.
void onPDMdata() {
  // Query the number of available bytes
  int bytesAvailable = PDM.available();
  // Read into the sample buffer
  PDM.read(sampleBuffer, bytesAvailable);
  // 16-bit, 2 bytes per sample
  samplesRead = bytesAvailable / 2;
