Get Request disables Light Sensor
Hi there,
I used the Web example to communicate with the Arduino board. It works fine for analog output, like external LED and Servo-Motor signals.
Now I tried to read out the signal from an ambient light sensor ( sparkfun). It also works fine, printing out in serial.
But once a server request is coming in, the light sensor is gone.
Output
setup()
IP Address: 192.168.178.46
signal strength (RSSI):-56 dBm
Ready to sense some light!
Ambient Light Reading: 7 Lux << perfect!
Reading settings...
Gain: 0.125 Integration Time: 100
First web request in loop():
new client
GET /ledAn HTTP/1.1
Accept: /
Host: arduino1
User-Agent: blah
Test 'light.begin() '
Could not communicate with the sensor!
Ambient Light Reading: 255 Lux << bad
client disconnected
What is happening? How is the light sensor disabled by a web request? What errors did I make?
Please help.
  WiFiClient client = server.available();  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    String currentLine = "";  // make a String to hold incoming data from the client
    if (client.connected()) {
      int bytes = client.available();
      if (bytes > 0) {
        // read the whole http request
        String request = "";
        for (int i = 0; i < bytes; i++) {
          char c = client.read();
          request += c;
        // print the http request
        Serial.println(request);
        if (request.indexOf("ledAn") != -1) { digitalWrite(ledPin, HIGH); };
        if (request.indexOf("ledAus") != -1) { digitalWrite(ledPin, LOW); };
        if (request.indexOf("motor") != -1) { motor(); };
        if (request.indexOf("drueck") != -1) { knopfdruecken(); };
      for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
        int sensorReading = analogRead(analogChannel);
        client.print(analogChannel);
        client.print(" is ");
        client.print(sensorReading);
      if (light.begin())
        Serial.println("Ready to sense some light!");
        Serial.println("Could not communicate with the sensor!");
      luxVal = light.readLight();
      client.print("Ambient Light Reading: ");
      client.print(luxVal);
      client.println(" Lux");
      client.println(luxVal);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
which one exactly ?
Show ALL the code.
This one, VEML6030
( SparkFun Ambient Light Sensor - VEML6030 (Qwiic) - SEN-15436 - SparkFun Electronics)
Hopefully it will help.
#include <Wire.h>
#include "WiFiS3.h"
#include <Servo.h>
#include "SparkFun_VEML6030_Ambient_Light_Sensor.h"
#define AL_ADDR 0x48
int keyIndex = 0;              // your network key index number (needed only for WEP)
int status = WL_IDLE_STATUS;
const int ledPin = 13;
WiFiServer server(80);
SparkFun_Ambient_Light light(AL_ADDR);
// Possible values: .125, .25, 1, 2
// Both .125 and .25 should be used in most cases except darker rooms.
// A gain of 2 should only be used if the sensor will be covered by a dark
// glass.
float gain = .125;
// Possible integration times in milliseconds: 800, 400, 200, 100, 50, 25
// Higher times give higher resolutions and should be used in darker light.
int zeit = 800;
long luxVal = 0;
  //Initialize serial and wait for port to open:
  Wire.begin();
    while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
    if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true)
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
  Serial.println("Motor");
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  myservo.write(0);
  Serial.println("Light");
  if (light.begin())
  Serial.print("Ambient Light Reading: ");
  Serial.print(luxVal);
  Serial.println(" Lux");
  Serial.println(luxVal);
  light.setGain(gain);
  light.setIntegTime(zeit);
  Serial.println("Reading settings...");
  Serial.print("Gain: ");
  float gainVal = light.readGain();
  Serial.print(gainVal, 3);
  Serial.print(" Integration Time: ");
  int timeVal = light.readIntegTime();
  Serial.println(timeVal);
/*  this works
  if (client) {
      if (bytes > 0) {
          request += c;
      if (light.begin())
    client.stop();
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Here the whole picture -
To the right, the request
Below the answer, with 'Ambient Light Reading: Lux' 225, which means failure.
Serial output shows first successful sensor reading, but after the request the 'could not communicate' message.
May be helpful, if this part is invoked, the Sensor gives a '0' in the setup
/* while (!Serial) {
Found a 'solution' by myself. However, the code is fragile, as the web server implementation seems to be. For example, when I change client.println to client.print, it stops working. Additionally, not everything comes through.
But so far I can use it as input for the solar energy logic.
Here is the code:
  WiFi Web Server
  Find the full UNO R4 WiFi Network documentation here:
  https://docs.arduino.cc/tutorials/uno-r4-wifi/wifi-examples#wi-fi-web-server
#include <Wire.h>
#include <WiFiS3.h>
#include "/home/me/Desktop/Arduino/Test/WiFiWebServer/arduino_secrets.h"
#include <SparkFun_VEML6030_Ambient_Light_Sensor.h>
// glass.
float gain = .125;
int zeit = 800;
long luxVal = 0;
  Wire.begin();
    // don't continue
    while (true)
    delay(10000);
  server.begin();
  printWifiStatus();
  if (light.begin())
  if (client) {
      if (bytes > 0) {
          request += c;
        if (light.begin())
    client.stop();
  Serial.println(ip);
  Serial.print(rssi);
After flashing the firmware, it stopped working ..
