I have this piece of code:
float test =0;
test = (4194304/(r+(65536*oflow)));
All the components are integers, however I wish to have the result in the form of a float.
How to achieve this?
Regards
float test =0;
Regards
Make the integers non integers, or cast them to be floats.
AWOL:
As in defining them as floats? Thats a waste of memory ![]()
There are other ways but this will do it.
test = (4194304./(r+(65536.*oflow)));
Pete
el_supremo:
There are other ways but this will do it.test = (4194304./(r+(65536.*oflow)));Pete
Cool. I've also found this thread that seems to shoe a few other methods http://forum.arduino.cc/index.php/topic,28742.0.html
I'm not sure how you've defined all of the variables, but I'll assume that r and oflow are floats. Then try:
float test =0;
test = (4194304.0 / (r + (65536.0 * oflow)));
The use of the decimal point after numeric constants tells the compiler to use the float data type in the expression.
econjack:
I'm not sure how you've defined all of the variables, but I'll assume that r and oflow are floats. Then try:float test =0;
The use of the decimal point after numeric constants tells the compiler to use the *float* data type in the expression.
Thanks. None of those variables are floats, but apparently only one needs to be defined as such to have a float result.
I used test = (((float)4194304/(r+(65536*oflow))));
Now I wish my output is given, rounded up to the next integer. For example 0,60 or 0,99 should show as 1.
How can I achieve this?
floats print default two decimal places
try
Serial.println(myFloat, 0);
BulldogLowell:
floats print default two decimal placestry
No. I don't wish to print, I wish to store a variable a a rounded value, so that can later be processed by other parts of the code.
The only reason i need float is because the arduino doesn't round up by default.
Then, just round it then.
BulldogLowell:
I don't know how to do that, hence the question. How do I round up the result of a division!?
Take a look at your options:
#include <math.h>
float val = 3.5;
Serial.print("floor = ");
Serial.println(floorf(val));
Serial.print("round = ");
Serial.println(roundf(val));
Serial.print("ceil = ");
Serial.println(ceilf(val));
econjack:
Brilliant, Thank you so much
casemod:
AWOL:
Make the integers non integersAs in defining them as floats? Thats a waste of memory
How many bytes to represent 65536?
How many bytes to represent 65536.0?
AWOL:
casemod:
AWOL:
Care to go straight to the point?
My sketch was 2.5K, enabling a single float makes it 4.2K, everything else being equal.
A single float wont use that much memory, but I have an assumption that the compiler is not doing the best optimization
Both take 4 bytes so to say floats take more memory is a bit silly.
And what does that mean?
And does "enabling" two floats make the sketch 5.9K?
I think not.
AWOL:
I think not.
Most certainly not, I do get an increase of about 150bytes. That should be good for the float, so the missing 1.7K are still somewhere. Doing god knows what.
AWOL:
This is not the point and certainly not my concern. My concern is why the compiler reserves so much space for a float.
Grumpy_Mike:
Sketch size in KB, after a "unsigned long int" is replaced with a "float"
For a float constant or variable, the compiler reserves at most, four bytes.
