Getting azimuth and tilt
I'm using this device: https://witmotion-sensor.com/en-ca/products/witmotion-hwt906-high-precision-10-axis-military-grade-inclinometer-sensor-3-axis-gyro-accelerometer-angle-magnetic-quaternion-built-in-sca3300-temperature-compensation-chip-ip67-waterproof
to get this values :
Screenshot 2024-01-30 at 11.46.47 AM
I want to get the azimuth and tilt, is the azimut arctan( mag x, mag y) and will the tilt be : sqrt(pitch^2,roll^2) ?
Thank you for you help,
The documentation for that sensor is linked on the web site, and you should study it carefully.
To get azimuth requires that the magnetometer be calibrated in its final resting place. The best calibration overview and tutorial is this one: Tutorial: How to calibrate a compass (and accelerometer) with Arduino | Underwater Arduino Data Loggers
Tilt can be measured on two axes using the accelerometer, which for highest accuracy must also be calibrated. See this tutorial: How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing-DFRobot
Thank you, I'll take a look to these links
Are those topics not covered in the extensive sensor documentation?
I don't think I saw anything like that
You need to look at the docs more carefully. The manufacturer's software for that sensor includes calibration.
Oh, my bad, thank you very much
