Getting error while using usbKeyboard.h library
I have tried building a usb HID keyboard, I,ve downloaded the usbskeyboard library. I got the following errors while compiling the example code itself.
the error is ,
sketch_apr19a.cpp.o: In function UsbKeyboardDevice': D:\ARDUINO AND LIBRARIES\ARDUINO 1.0.6\libraries\UsbKeyboard/UsbKeyboard.h:139: undefined reference to usbInit()'
sketch_apr19a.cpp.o: In function UsbKeyboardDevice::update()': D:\ARDUINO AND LIBRARIES\ARDUINO 1.0.6\libraries\UsbKeyboard/UsbKeyboard.h:150: undefined reference to usbPoll()'
I'm sure that there is no error in the code, since I've tried a lot of codes from internet.
The example code which I tried,
#include "UsbKeyboard.h"
#define PIN_BUTTON 7 // the button is attached to pin 7
int lastState = LOW; // LOW is equivalent to 0
// button setup
pinMode(PIN_BUTTON, INPUT);
// USB setup -----------------
// Disable timer0 since it can mess with the USB timing. Note that
// this means some functions such as delay() will no longer work.
TIMSK0 &= !(1<TOIE0);
// Clear interrupts while performing time-critical operations
cli();
// Force re-enumeration so the host will detect us
usbDeviceDisconnect();
delayMs(250);
usbDeviceConnect();
// Set interrupts again
sei();
// update USB device state
UsbKeyboard.update();
// check, if transition to button-pressed has occured
if( (digitalRead(PIN_BUTTON) == HIGH) && (lastState==LOW) ) {
UsbKeyboard.sendKeyStroke(KEY_A); // if so, send the letter 'a' via USB keyboard
lastState = HIGH; // update the state variable
delay(10); // simple de-bouncing
// check, if the button was released
} else if( (digitalRead(PIN_BUTTON) == LOW) && (lastState==HIGH) ) {
lastState = LOW; // if so, update the state variable
// helper method for V-USB library
void delayMs(unsigned int ms) {
for( int i=0; i<ms; i++ ) {
delayMicroseconds(1000);
Please give me a solution to solve this error......
Which USBKeyboard library did you install? The one I found doesn't match your errors:
