I have then installed the Blynk Library and other neccessary parts (to my knowledge). I am trying to run a simple code of turning a LED ON/OFF using Blynk. The code is as follows:
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "...";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "...";
char pass[] = "...";
py
// Debug console
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
Blynk.run();
// You can inject your own code or combine it with other sketches.
// Check other examples on how to communicate with Blynk. Remember
// to avoid delay() function!
And this is the error I get
fork/exec /Users/.../Documents/Arduino/hardware/esp8266com/esp8266/tools/python3/python3: no such file or directory
exit status 127
Error compiling for board Generic ESP8266 Module.
After going trough this thread and following each step I still get the same error trying to compile the code...
What am I doing wrong? Is it supposed to be this hard getting esp8266 to work?
Cheers!
EDIT:
I forgot to mention that I am using a connection of Arduino Uno together with ESP8266. And I Just saw that my error message has changed a bit to this (without a directory link):
env: python3: No such file or directory
exit status 127
In file included from /Users/Pingi/Documents/Arduino/Code/test_ESP8266/test_ESP8266.ino:39:0:
/Users/Pingi/Documents/Arduino/libraries/Blynk/src/BlynkSimpleEsp8266.h:18:21: fatal error: version.h: No such file or directory
#include <version.h>
compilation terminated.
exit status 1
I don't understand what the problem is...
I have the latest Arduino Core
I have the latest ESP8266 Core
I have the latest of all required libraries (Blynk etc.)
