Getting inaccurate temperature readings using the LM35 and LCD display
Hi all,
I have used this exemplar project to build a temperature monitor: Arduino - Display Temperature from LM35 Sensor on LCD | Arduino Tutorial (arduinogetstarted.com)
I am using the LM35 sensor and the LCD 1602F ( I think) and unfortunately it is giving me very high readings.
my display says the temperature is 62 degrees centigrade, which is incorrect as it is actually about 20 degrees centigrade.
I have wired the board and coded it exactly as it is on the exemplar project as per the web link I attached to this thread so I'm not sure why I am getting such inaccurate readings?
I would be appreciative of any assistance that can be offered.
Thank you.
Is that Centigrade or Fahrenheit
Sorry i should have clarified, it is centigrade.
Difficult to say what the source of error might be. I would start by verifying LM35 working properly and that it responds temperature differences correctly.
Is there consistently 42 degrees too much in reading? Codes offset value might need fixing...
LM35 is supposed to raise its output voltage by 10mV/degree, so if room is about 20, then heating LM35 with your fingers should rise its output voltage about 150mV (20 -> 35).
It may not be clear in the picture they show in the tutorial but the flat side of the LM35 is facing towards you. Do you have it that way?
Yes
There have been quite a few hobbyist having problems with cheap breadboards.
The parts and wires sometimes don't make contact. Try wiggling the LM35 when it's running
It's to simple a project for anything to go wrong.
Which Arduino are you using?
Benchmark all your tools.
Look at the source code of libraries you are using. ~20C is so close to 62F it's pointless to speculate or try to interpret your code until you do some due diligence.
I tried that code on a UNO without the LCD and it works.
Arduino Uno
This is the code i am using:
#include <LiquidCrystal_I2C.h> // LCD I2C library
#define ADC_VREF_mV    5000.0 // in millivolt
#define ADC_RESOLUTION 1024.0
#define PIN_LM35 A0 // pin connected to LM35 temperature sensor
LiquidCrystal_I2C lcd(0x3F, 16, 2);  // LCD I2C address 0x27, 16 column and 2 rows
  lcd.init();      // initialize the lcd
  lcd.backlight(); // open the backlight
  int adcVal = analogRead(PIN_LM35);
  // convert the ADC value to voltage in millivolt
  float milliVolt = adcVal * (ADC_VREF_mV / ADC_RESOLUTION);
  // convert the voltage to the temperature in Celsius
  float tempC = milliVolt / 10;
  float tempF =  (tempC * 9/5) + 32; // convert Celsius to Fahrenheit
  lcd.clear();
  lcd.setCursor(0, 0); // start to print at the first row
  lcd.print(tempC);    // print the temperature in Celsius
  lcd.print("°C");
  lcd.setCursor(0, 1); // start to print at the second row
  lcd.print(tempF);    // print the temperature in Fahrenheit
  lcd.print("°F");
  // print the temperature to Serial Monitor
  Serial.print(tempC);
  Serial.print("°C ~ ");
  Serial.print(tempF);
  Serial.println("°F");
  delay(60000);
One of the outputs i am getting - this is not correct. The temperature of the room is aprox 20 degrees celcius.
As I already pointed out:
I used the exact same code on an UNO but without the LCD and it works fine.
Unfortunately it is not working for me.
The LM35 must be BAD
I am not sure if perhaps the LCD i am using does not match the one being used in the project i am following? This is the LCD I am using
It does not matter.
Do you see the same wrong numbers in the serial monitor output?
Yes, they are the same as what is being outputted on the LCD.
