Getting Json from URL and Displaying data
Hey I'm using HttpClient and Arduino Json Lib .
My code look like that:
#include <ArduinoJson.h>
#include <Bridge.h>
#include <HttpClient.h>
  Bridge.begin();
   HttpClient client;
  // Make a HTTP request:
  client.get("http://18003.hosts.ma-cloud.nl/light/lightStatus.php");
 while(client.available()){
  char c = client.read();
char json[] = c;
// Step 1: Reserve memory space
StaticJsonBuffer<200> jsonBuffer;
// Step 2: Deserialize the JSON string
JsonObject& root = jsonBuffer.parseObject(json);
if (!root.success())
  Serial.println("parseObject() failed");
  return;
// Step 3: Retrieve the values
const char* sensor    = root["status"];
Serial.print(sensor);
  // Initialize the client library
Website http://18003.hosts.ma-cloud.nl/light/lightStatus.php
Give me following json:
{\"id\":\"1\",\"status\":\"0\"},{\"id\":\"2\",\"status\":\"1\"},{\"id\":\"3\",\"status\":\"0\"},{\"id\":\"4\",\"status\":\"1\"}
If I assign json data to variable like that:
char json[] = "{"id":"1","status":"0"},{"id":"2","status":"1"},{"id":"3","status":"0"},{"id":"4","status":"1"}";
It works correctly.
But if I want to get it from the url so not hardcoded.
When i use:
char json[] = c;
I get following error:
C:\Users\Artur\Desktop\XlabJson\XlabJson.ino: In function 'void setup()':
XlabJson:28: error: 'json' was not declared in this scope
exit status 1
Please Help !! Deadline is comming :frowning:
Deadline is comming
Bummer. Too bad you are not going to have enough time to learn about pointers and arrays and the relationship between them in time.
   char *stupidJSONcrap = client.get("someStupidURLThatReturnsJSONCrap");
Yea...
Thanks for answer, I'm a real new in C and Arduino, I know PHP,Python well....
I tryed to use your answer to make it right but It does not work.
Return 1 , I need to use second function :
to get currect json from url. So your answer won't help me? Of am I wrong?
All of your code is where?
If you are going to read the response one character at a time, you'll need to determine a maximum number of characters that can reasonably be in a response, and allocate an array that size to store the data in. Then, read and store each character, in the appropriate position, followed by a NULL.
You were the one that suggested that client.get() returned an array of data.
How should It look like. I really don't get it...
I tryed to do it like that:
   HttpClient client;
  char *stupidJSONcrap = client.get("http://18003.hosts.ma-cloud.nl/light/lightStatus.php");
 client.available();
  char json[] = stupidJSONcrap;
Also tryed:
 client.available();
  char c = stupidJSONcrap.read();
  char json[] = c;
I was trying to use your answer all the way but still I get some errors...
int index = 0;
char uselessJSONCrap[120];
while(client.connected())
   while(client.available() > 0 && index < 118)
      uselessJSONCrap[index++] = client.read();
      uselessJSONCrap[inex] = '\0';
parseUselessJSONCrap(uselessJSONCrap);
If you get the impression that I do not care for JSON, you are correct. Unreadable crap that has no advantage over XML.
What do you mean with
