I'm doing a project using the sparkfun RFID shield SparkFun RFID Evaluation Shield - 13.56MHz - DEV-10406 - SparkFun Electronics and RFID module RFID Module - SM130 MIFARE® (13.56 MHz) - SEN-10126 - SparkFun Electronics.
In the project, when a RIFD tag is placed on the reader and sends out a serial.println - this is pretty standard and already works in the sample code. What I want to do however is have it send a new Serial message when the tag is removed. I'm not to sure about how to go about doing this and any help would be really appreciated.
I've added the sparkfun sample code that I'm currently using below:
#include <SoftwareSerial.h>
int incomingByte = 0;
SoftwareSerial rfid(7, 8);
SoftwareSerial xbee(10, 9);
//Prototypes
void check_for_notag(void);
void halt(void);
void parse(void);
void print_serial(void);
void read_serial(void);
void seek(void);
void set_flag(void);
//Global var
int flag = 0;
int Str1[11];
//INIT
Serial.println("Start");
// set the data rate for the SoftwareSerial ports
xbee.begin(9600);
rfid.begin(19200);
delay(10);
halt();
//MAIN
read_serial();
void check_for_notag()
seek();
delay(10);
parse();
set_flag();
if(flag = 1){
seek();
delay(10);
parse();
void halt()
//Halt tag
rfid.write((uint8_t)255);
rfid.write((uint8_t)0);
rfid.write((uint8_t)1);
rfid.write((uint8_t)147);
rfid.write((uint8_t)148);
void parse()
while(rfid.available()){
if(rfid.read() == 255){
for(int i=1;i<11;i++){
Str1[i]= rfid.read();
void print_serial()
if(flag == 1){
//print to serial port
Serial.print(Str1[8], HEX);
Serial.print(Str1[7], HEX);
Serial.print(Str1[6], HEX);
Serial.print(Str1[5], HEX);
check_for_notag();
void read_serial()
seek();
delay(10);
parse();
set_flag();
print_serial();
delay(100);
void seek()
//search for RFID tag
rfid.write((uint8_t)130);
rfid.write((uint8_t)131);
delay(10);
void set_flag()
if(Str1[2] == 6){
flag++;
if(Str1[2] == 2){
flag = 0;
