#include <LED.h>
#include <bitswap.h>
#include <chipsets.h>
#include <color.h>
#include <colorpalettes.h>
#include <colorutils.h>
#include <controller.h>
#include <cpp_compat.h>
#include <dmx.h>
#include <FastLED.h>
#include <fastled_config.h>
#include <fastled_delay.h>
#include <fastled_progmem.h>
#include <fastpin.h>
#include <fastspi.h>
#include <fastspi_bitbang.h>
#include <fastspi_dma.h>
#include <fastspi_nop.h>
#include <fastspi_ref.h>
#include <fastspi_types.h>
#include <hsv2rgb.h>
#include <led_sysdefs.h>
#include <lib8tion.h>
#include <noise.h>
#include <pixelset.h>
#include <pixeltypes.h>
#include <platforms.h>
#include <power_mgt.h>
#define NUM_LEDS 54
#define LED_PIN 7
CRGB led[NUM_LEDS]
pinMode(7, 5);
FastLED.addLeds<NEOPIXEL, LED_PIN>(led, NUM_LEDS);
for (int i = 0; i < NUM_LEDS; i++) {
led[i] = CRGB(0,0, 255);
FastLED.show()
void setBlue(int val) {
for (int i = 0; i < NUM_LEDS; i++){
led[i] = CRGB(0, 0, val);
FastLED.show()
for (int i = 255; i > 0; i++) {
setBlue(i);
delay(300)
Here is the error message
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\cathe\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\cathe\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\cathe\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10801 -build-path C:\Users\cathe\AppData\Local\Temp\arduino_build_557767 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\cathe\Documents\Arduino\sketch_feb21a\sketch_feb21a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\cathe\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\cathe\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\cathe\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10801 -build-path C:\Users\cathe\AppData\Local\Temp\arduino_build_557767 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\cathe\Documents\Arduino\sketch_feb21a\sketch_feb21a.ino
Using board 'uno' from platform in folder: C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23
Using core 'arduino' from platform in folder: C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23
Detecting libraries used...
"C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\variants\standard" "C:\Users\cathe\AppData\Local\Temp\arduino_build_557767\sketch\sketch_feb21a.ino.cpp" -o "nul"
"C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\variants\standard" "-IC:\Users\cathe\Documents\Arduino\libraries\LED" "C:\Users\cathe\AppData\Local\Temp\arduino_build_557767\sketch\sketch_feb21a.ino.cpp" -o "nul"
"C:\Users\cathe\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\cathe\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\variants\standard" "-IC:\Users\cathe\Documents\Arduino\libraries\LED" "C:\Users\cathe\AppData\Local\Temp\arduino_build_557767\sketch\sketch_feb21a.ino.cpp" -o "C:\Users\cathe\AppData\Local\Temp\arduino_build_557767\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\cathe\Documents\Arduino\sketch_feb21a\sketch_feb21a.ino:3:0:
C:\Users\cathe\Documents\Arduino\libraries\LED/LED.:23:23: fatal error: WProgram.h: No such file or directory
compilation terminated.
Using library LED in folder: C:\Users\cathe\Documents\Arduino\libraries\LED (legacy)
exit status 1
Error compiling for board Arduino/Genuino Uno.
I've also been getting more errors with the void setup and void loop
If anyone can help that would be amazing! ![]()
Edit: The compiler error has been fixed, thanks! However, I have been running into a new error.
C:\Users\cathe\Documents\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.001
# pragma message "FastLED version 3.002.001"
sketch_feb21a:36: error: expected initializer before 'void'
Using library FastLED at version 3.2.1 in folder: C:\Users\cathe\Documents\Arduino\libraries\FastLED
exit status 1
