I'm new to Aduino and I'm having trouble with a project using a Duemilanove and an LS20031 GPS reciever module from Sparkfun. I've tried looking though the forums and using the GPS tutorial code without any luck. For the most part I've tried variations on the code below just as a test. I either get -1's or y's with an umlaut depending on the changes I make. The strange thing is that when I hold the reset button the GPS data is automatically spit out to the serial monitor window. Any help will be greatly appreciated.
"-1" says you're reading the serial buffer when it is empty, i.e. you're not waiting for "Serial.available".
"loop" runs much faster than 5760 characters per second can keep up with.
It isn't necessary to set the I/O mode of the serial pins.
I tried making the following changes to the code, but still no luck. The program doesn't display anything other than what I write to the serial monitor. The debugging LED doesn't change at all as though the GPS isn't sending any data.
You do have the receive pin of the GPS hooked up to the transmit pin of the arduino and vice versa right? I know that when I picked up a GPS module that threw me for a moment...
